Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 01-22-2009, 06:19 PM   #1
KS&Dracing
KS&Dracing is on a distinguished road
Default Ion sedan turbo?
Can you put a turbo into the saturn ion sedan? i have an 03 ion 2.2 non turbo and i want to turbo it. i have no idea where to look for one or anything. also i have a cold air intake on it and i am trying to find anything i can do to add power. if anyone has any ideas please let me know. I also am thinking about nitrous such as a 50-75 shot but im not sure how much that helps in hp gain. Any help is great Thank you.
Add to KS&Dracing's Reputation
Rate the quality of this post and help KS&Dracing reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KS&Dracing is offline   Reply With Quote
Old 01-22-2009, 06:26 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Ion sedan turbo?
whatever you do, I recommend you put pods and pistons in. from there you need to find a shop that can dyno tune a 2.2 from 2003, though you are limited how much you can boost it by your ECM (and no, you can't switch it out). also, there are no kits, so you'd be making your own setup.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 01-22-2009, 10:25 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
go to a chevy or pontiac dealer and ask for a gm performance catalog and/or the ecotec cookbook. here's a link http://media.gm.com/division/gmracin...ingecotec.html
it shows the parts needed to build something like 300 to 650 hp from an ecotec. see if you can find a 2.0L supercharged ecotec from a wreaked ion red line and put that in your ion sedan as a starting point
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-23-2009, 12:54 AM   #4
2006 ion2
2007 ION-2 Sedan
you still need a tuner before you put the SC or turbo on it. it gives you ideas, not actual P/Ns, at least the one I looked at didn't.
2007 Saturn Ion 2
Old 01-23-2009, 04:57 AM   #5
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
best route would be nitrous + full boltons.. there is no ecm tuning avalable for the year your ion was made. so the only reliable way would be nitrous..
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 01-23-2009, 08:11 AM   #6
2006 ion2
2007 ION-2 Sedan
there's no wide tuning support, but some shops can dyno tune them
2007 Saturn Ion 2
Old 01-23-2009, 09:17 AM   #7
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Thumbs Down Re: Ion sedan turbo?
Originally Posted by 2006 ion2 View Post
...you are limited how much you can boost it by your ECM...
??? how do u figure this?
oh? do tell how that's possible w/o a standalone
OP, head over to ionforums.net and do some searching. there are plenty of n2o installs doc'd there as well as some supercharger and turbo ones. enjoy. and as far as how much hp a 50-75 shot of n2o will give you, the answer is 50-75hp - that's how the "shots" of n2o get their names.......
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 01-23-2009, 10:48 AM   #8
2006 ion2
2007 ION-2 Sedan
I've talked to someone who has dyno tuned them and they said because the old ECUs are slower, they can't keep up with a lot of boost. some shops have figured out how to tune these ECUs, but no one has a tuner for them yet.
2007 Saturn Ion 2
Old 01-23-2009, 03:53 PM   #9
06_Ion2
06_Ion2's Avatar
id honestly like to know where your getting your information from... because i dont believe any of it.. the only tuneable ecm years are the 05-07...
Old 01-23-2009, 04:06 PM   #10
bc3tech
bc3tech's Avatar
2007 AURA XR
ditto. because they're slower??? please.
Old 01-23-2009, 08:53 PM   #11
KS&Dracing
I was looking and i found a "super turbo" for the 03 ion but im not sure how smart getting that for it would be. any ideas? and also would it just be better to sell this car. cut my losses and go for an 05+ ion RL? and if i didnt where could i get the nos at?
Old 01-23-2009, 08:55 PM   #12
KS&Dracing
also how can i get rid of the dang gov on it... it cuts out just around 107-108 mph
Old 01-24-2009, 11:43 AM   #13
2006 ion2
2007 ION-2 Sedan
the 2003 compared to the 2005 ECU operates at a slower bit rate, it reads the info from the engine with less samples per minute than the newer ECU, in 2007 they upgraded to a 58x crankshaft position sensing and a 32-bit computer, making it even faster.
2007 Saturn Ion 2
Old 01-26-2009, 12:26 PM   #14
KS&Dracing
so there is no way to get rid of the gov on it?
Old 01-26-2009, 01:09 PM   #15
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
I can't tell you how to change the speed control, but I can tell you why they set it.
The speed is controlled to match the tire rating of the stock tires.
One of the ways tires are rated is the top speed they are made to handle. For liability reasons, they control the top speed of the car so as to not exceed the speed which the tires can handle.
So, if you DO spend the money to upgrade your engine, you'll probably also need to upgrade your rubber.
Add to daver's Reputation
Rate the quality of this post and help daver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daver is offline   Reply With Quote
Old 01-26-2009, 01:42 PM   #16
KS&Dracing
kk thanks i have upgraded my tires too lol i have hancook (sp?) lol i just want to remove the speed limitor cuz ill be racing someone hit 108 and slow back down... 108 on my car is around 4000 rpms in 5th so there is still a ways it can go... and i get passed at 108 by cars that dont have a top limitor... its sad
Old 01-26-2009, 01:47 PM   #17
2006 ion2
2007 ION-2 Sedan
the governor, rev limiter, PE mode, the slow revving nature of the engine (not up, but down) these are all things solved by tuning.
2007 Saturn Ion 2
Old 01-29-2009, 04:49 PM   #18
KS&Dracing
so where again can i get my car tuned?
Old 01-29-2009, 08:29 PM   #19
2006 ion2
2007 ION-2 Sedan
and I meant rods, not pods.
2007 Saturn Ion 2
Old 09-08-2009, 07:09 AM   #20
fuzyion
fuzyion is on a distinguished road
where would you look for a wrecked redline to take the 2.0 out?
Add to fuzyion's Reputation
Rate the quality of this post and help fuzyion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fuzyion is offline   Reply With Quote
where can i get a Turbo Monifold for ion 2 sedan 03 AlexLugones Ion Mods 6 09-22-2008 11:38 PM
Want to get Ion 3 Sedan faba_2005 Ion General 4 05-02-2007 07:37 PM
Loaded ION 3 Sedan vs. Base L300 sedan Caprice General Saturn Discussion 32 02-26-2004 03:29 PM
ION QC weighs more the ION Sedan? Wrxified Ion General 24 07-18-2003 10:55 PM
ION (sedan) and ION (Coupe) Swizelman45 Ion General 13 08-12-2002 03:14 PM
