Old 12-14-2007, 04:21 PM   #1
Jims97
Jims97 is on a distinguished road
Default AC relay help please
I have a 97 SL2. I want to use the pushbutton AC switch beside the recurculate sw to run an aux. heater. Well, actually I want to use the wire for the compressor to run the aux. so it runs through the relay.
System is all cleaned out, lines, compressor, cond. drier are all removed and pressure switch wires are spliced. The problem is when the AC button is pushed in, the relay does not come hot thereby not powering the compressor wire. Battery power to relay is good, ing. switched power comes on properly, but the relay won't switch to the compressor feed wire. If I pull the relay up to where it still makes contact but can still get my test light probe under it, touching the 86 spade will cause the contactor to close and power the 87 compressor wire as normal. My question is, what am I missing that excites the relay to work.
Add to Jims97's Reputation
Rate the quality of this post and help Jims97 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jims97 is offline   Reply With Quote
Old 12-14-2007, 06:32 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: AC relay help please
Double check the ground to the relay.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-14-2007, 09:08 PM   #3
Jims97
Wouldn't happen to know where it grounds to would you?
I'm more familiar with the Bosch relays that have 5 connectors, one being ground. This Seimens only has 4, so I'm guessing it has to ground elsewhere.
Thanks
Old 12-14-2007, 09:45 PM   #4
richpin06
richpin06's Avatar
Ground should be present at socket #85 on the box.Just remove the relay and check the socket.
Just got my new Relay 3 NewToSaturn2 Relay General 9 04-12-2005 05:36 PM
Relay saturncanuck Relay General 58 01-20-2005 07:01 PM
Relay corey@okemos Relay General 13 11-09-2004 01:48 PM
Relay saturncanuck Relay General 7 11-08-2004 12:52 PM
Relay... Yokozuna Relay General 16 12-03-2003 05:20 PM
