Old 06-18-2007, 06:41 AM   #1
BarnOwl
BarnOwl's Avatar
2000 SW2
Default '99a or '99b?
I have an opportunity to buy yet another SW. This will make 3. I haven't been able to look at it yet but, from the description, this one has a rod knock. I have a '97 engine with what's probably an okay bottom end. My problem is that the wagon's a '99. So, if it's '99b, the bottom end won't fit. What's the easiest way to tell, just looking at the engine?
Add to BarnOwl's Reputation
Old 06-18-2007, 09:05 AM   #2
fashions
fashions is on a distinguished road
Default Re: '99a or '99b?
barnowl, with the vin # you could get production date from dealer which would give you some more information to decide if its early or late.
Add to fashions's Reputation
Rate the quality of this post and help fashions reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fashions is offline   Reply With Quote
Old 06-18-2007, 12:53 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
A 1997 engine will go into a 1999 with no problems. We have a 1999 SC2 with a 1997 engine.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Low Saturn is online now   Reply With Quote
Old 06-18-2007, 01:14 PM   #4
BarnOwl
BarnOwl's Avatar
2000 SW2
You misunderstand what I'm asking. I want to put the '99 head on the '97 block. That is supposed to work for some '99s. I want to know how to tell which this one is.
Old 06-18-2007, 01:23 PM   #5
madpogue
1996 SW2
Isn't the later head the narrower one, with the cams spaced closer together? No molded "snaps" for the spark plug wires between the cam spaces on the cam cover? And isn't this also the one with a 9-stud exhaust manifold, vs. the old 5-stud? Or am I getting my transitions all mixed up?
Add to madpogue's Reputation
Old 06-18-2007, 01:35 PM   #6
BarnOwl
BarnOwl's Avatar
2000 SW2
AFAIK that's correct. The 9 versus 5 studs on the exhaust manifold is the kind of thing I was looking for. I'd forgotten about that one. I didn't know about the molded snaps. I'll have to take a look at my SW2 to check that out. The narrower head is and cam spacing are a little hard to see just looking at the engine.
Old 06-18-2007, 01:56 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
The 1999 head, no matter which one it is will bolt up the the 1997 block. If thats what you're asking. It an hour and a half to lunch, I'm starving and not thinking clearly.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 06-18-2007, 02:02 PM   #8
BarnOwl
BarnOwl's Avatar
2000 SW2
That I didn't know but, you are the guy that I knew would. So, I guess the narrower head didn't show up until 2000. Thanks very much.
Old 06-18-2007, 02:10 PM   #9
madpogue
1996 SW2
I don't think that's what he means. I think he means that the block is not changed, so either the wider or narrower head will fit the '97 block. But now I'm hungry, too (LATE lunch time here in the Central TZ).
Old 06-18-2007, 02:22 PM   #10
Low Saturn
Low Saturn's Avatar
2000 SC2
Yeah, thats it.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 06-18-2007, 02:23 PM   #11
BarnOwl
BarnOwl's Avatar
2000 SW2
Forgive me for being dense but, I would think that if the head was actually narrower, it wouldn't bolt up to a block made for a wider head. I don't mind it if I'm wrong about that. I want the block to go in the '99 not in the '97. So, it works for me regardless.
Old 06-18-2007, 02:27 PM   #12
madpogue
1996 SW2
I'm oversimplifying, but -- the top of the head is narrower; less spacing between the cams. The bottom of the head is the same. Think of it this way (wavering OT): the SOHC head is way narrower than either one, and it fits the very same block.
Old 06-18-2007, 02:41 PM   #13
Low Saturn
Low Saturn's Avatar
2000 SC2
Couldnt of put it better myself.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 06-18-2007, 07:21 PM   #14
geartooth94
geartooth94 will become famous soon enough
geartooth94's Avatar
yes the timing cover, exhaust manifold and valve cover will be different also, i think
1996 Dodge Avenger ES: 2.5L V6
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 06-22-2007, 06:37 PM   #15
fashions
came across this post and thought it could help id '99 motors
Re: Torque specs Rods/Mains
These "new" rods appeared in the LATE 99' model year engines with the "improved" rods and pistons. (Look for the lovely plastic intake to identify a late 99' DOHC engine. All 00' ~ 02' have these rods...., wolfman
