Old 01-23-2020, 01:47 AM   #1
me.theuser
me.theuser is on a distinguished road
2002 SL1
2001 SL2
Information MEvotech LCA NFG -- STAY AWAY!!
I bought Mevotech LCAs thinking greasable ball joints for my lower control arms might be a good thing
So far I've installed two drivers side and one passenger LCA
The first driver side LCA wouldn't take grease and when I tried it popped the lower metal cap
Second driver side LCA took grease and started popping after a spirited test drive
Passenger side went on fine and took grease started popping after 300 miles!
So I went and bought MOOG (which I should have done the first time)
Car is finally good after installing LCA's 5x
Verdict: Mevotech LCA stay away!!
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
me.theuser is offline   Reply With Quote
Old 01-23-2020, 01:52 AM   #2
Zeebins
Zeebins's Avatar
Default Re: MEvotech LCA NFG -- STAY AWAY!!
Are the MOOG ares also greaseable?
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 01-23-2020, 02:26 AM   #3
me.theuser
2002 SL1
2001 SL2
Unfortunately no they are not greaseable but I have a set of MOOG LCAs on my SL2 that are just starting to go out.
Originally I thought I had put them on two years ago so I went looking for another brand but after looking up the receipts it turns out it was 4 years ago so thats around 75,000 miles Ive put on them better than 0-300 miles
Still I'd like to get 100,000+ like the originals
Old 01-23-2020, 09:55 AM   #4
trottida
trottida's Avatar
Was that the Mevotech Supreme or the economy grade?
I'm running the Supreme and haven't had any issues.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 01-23-2020, 10:11 AM   #5
With Moog it's hit & miss on the grease fitting. Part number doesn't matter. I've had identical labels on box's and gotten 1 of each (checked at home 45min from the store..."too late to fix now").
Old 01-23-2020, 11:31 AM   #6
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
I read in an early thread that you modified the zerk fittings so you could grease the control arms with the wheels on - would that void the lifetime limited warranty of your Mevotechs? Just curious.
I tend to really research out the warranty/pros & cons of anything I replace since I put less than 8,500 miles on my car a year.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-23-2020, 11:46 AM   #7
me.theuser
2002 SL1
2001 SL2
https://www.rockauto.com/en/moreinfo.php?pk=6114210
I've no clue which these are but this what I ordered
what I received looks just like em, except they had a metal clip around the boot that looks like a key ring
Old 01-23-2020, 12:06 PM   #8
Zeebins
Zeebins's Avatar
That is the one that I bought last June that also didnít work.
fetchitfido, how long ago was it you did your control arms? Iíve had a theory that they are on a bad batch of drivers side control arms.
Powered by Plastic
Old 01-23-2020, 12:28 PM   #9
trottida
trottida's Avatar
You have to install the grease zerks yourself and I can't see voiding the warranty based on installing 90 degree grease zerks. It doesn't change the operation and performance one bit. Just the path that the grease takes.
I actually called MevoTech's customer support line and suggested they change what they supply from the factory and the reasons why. They said it was a good idea and that they would forward it up the chain.
Yes, those are the same ones. I ordered them from RockAuto.com as well.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-23-2020, 02:03 PM   #10
Zeebins
Zeebins's Avatar
I just realized I asked the wrong person that question
*ahem* Trottida, when did you install your control arms?
Powered by Plastic
Old 01-23-2020, 03:20 PM   #11
trottida
trottida's Avatar
Originally installed May 2018 and you've got a good memory; I replaced the front left LCA under warranty in early June 2019 due to a worn ball joint. Actually I warrantied both of them even though the right one seemed good. I had forgotten about that.
That said, after the initial LCA install I ran the car for 5 months on a botched alignment which destroyed my front tires and subsequently at the 8 month mark I had to replace the left hub bearing assembly. I chalked the early LCA failure at 13 months (8K km) up to the stress of the alignment issue and/or the bad hub bearing assembly issue.
Since June 2019 I've put about 24K km (15K mi) on the car and the LCA has not given me any issues.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-23-2020, 03:53 PM   #12
focusofheart
...Still I'd like to get 100,000+ like the originals
I replaced both original lower control arms and tie rods at about 220,000 miles last month although I only have one of the original inner tie rods. I replaced the original shocks and struts at about 215,000 miles. The original sway bar bracket bushings were replaced at about 219,000 miles.
Is it normal for original parts to last that long or is it because I live in California, closely maintain my car and drive like a grandma?
Old 01-23-2020, 11:23 PM   #13
Zeebins
Zeebins's Avatar
I get free shipping and free returns on Amazon thanks to Prime, so I may just keep buying and exchanging control arms this spring just to see if I can get eventual get a good one.
Powered by Plastic
Old 02-11-2020, 11:13 AM   #14
TomM96
A lubrication accessory is a 'needle' type that attaches to grease gun...
it facilitates grease injection thru/under/between apertures about 1/16".
TRW LCAs are/were available from Taiwan (maybe via PartGeek).
Quality suspension components are available through NAPA...
ask for DANA components.
Suspension & brake component failure can potentially result in lost lives; also consider the value of the labor involved.
MY Rule for used car operations, is that repairs need to last at least 8 years or 80k Miles, else always maintaining the car....
Add to TomM96's Reputation
Old 02-11-2020, 11:30 AM   #15
Waiex191
Waiex191's Avatar
Our Mevotech premium LCAs seemed ok. I'll report status on the next oil change.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Mevotech Front Wheel Bearings carvinbassplyr Vue General 6 11-26-2015 11:28 PM
Noisy Mevotech Strut Mounts chad53916 S-Series Tech 13 09-10-2013 03:30 PM
Rock Auto MEVOTECH Strut Mounts..... Nick96'SL2 S-Series Tech 1 04-27-2011 12:27 AM
