Old 12-15-2019, 11:54 PM   #1
Zeebins
Zeebins's Avatar
Default Electric trunk latch swap question
I recently learned that the remote for my alarm system could be wired to remotely pop the trunk. This was never set up though due to the trunk latch being mechanical. I want to get an electric trunk latch, as well as the wiring, from the junkyard to replace my mechanical one to be able to remotely open the trunk. I had a few questions about it though...
What years/body styles can I get a en electric switch from?
Can the mechanical lever next to the seat be connected to the electric latch or would I have to convert that lever to electric too?
Thanks for the help
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 12-16-2019, 12:54 AM   #2
Default Re: Electric trunk latch swap question
Every '97 I've owned (5+) with power locks (4+) had a truck pop button on the fob. They were from various build times, some late '96 some early '97 so it wasn't some mid-year change.
Should be the same '97-'99 and I believe only the wagons got a funky one.
Old 12-16-2019, 08:26 AM   #3
Waiex191
Waiex191's Avatar
My 98 coupe has an electric trunk pop solenoid that doesn't work and a mechanical one that does.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 12-16-2019, 11:37 AM   #4
Broken wire or broken solenoid coil? I have both in my L300 and rarely use the mechanical trunk release. Easier to press either my remote or button in the car. Using my key only to test it infrequently.
Old 12-16-2019, 12:01 PM   #5
Cars with the mechanical cable (1998 and up) still had an electric release for use with the RKE fob.
1997 and older had the electrical release by the driver side seat. Kinda sucks because my 1997's battery has been dead for years and I have to use the key to open the trunk (I call it a project car but haven't touched it in over 5 years, other than to steal parts from it )
Model changes are in this handy Word document
http://www.saturnfans.com/Cars/s-ser...lchanges.shtml
Old 12-16-2019, 04:00 PM   #6
robfike
robfike is on a distinguished road
robfike's Avatar
2000 SW2
My 2000 SW2 wagon has electric locks and electric rear hatch release.
Add to robfike's Reputation
Rate the quality of this post and help robfike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robfike is offline   Reply With Quote
Old 12-16-2019, 10:49 PM   #7
Zeebins
Zeebins's Avatar
It sucks at the junkyard too when you find a car with no battery, like they usually are, and it has an electronic trunk latch. Good to know I can keep my mechanical latch though. I think thereís a few 2nd gens at the junkyard RKE, but with it showing tomorrow I have no idea when Iíll get to go.
Powered by Plastic
Old 12-17-2019, 11:40 AM   #8
This is for your '97? That should be an electrical latch at the driver seat (wont' work without battery) unless it has already been swapped.
Good point about the JY - think I ran into that when pulling a tail light lens once.
Old 12-17-2019, 11:54 AM   #9
Zeebins
Zeebins's Avatar
Itís definitely mechanical. I think it was only an electric switch if you had power locks/RKE already. Iíve never really payed attention to the switch/ latch combo of Saturns at the junkyard before, but thatís how mines set up anyway.
Powered by Plastic
Old 12-17-2019, 12:23 PM   #10
Didn't know there was actually a different latch, I figured one just had the electric release hacked on and the other didn't.
21170645 Lock W/ ELECTRIC
21170644 Lock W/ O ELECTRIC
Both numbers say '96-'99 any model.
Old 12-17-2019, 01:25 PM   #11
Oh, that makes sense. Thanks. I don't think I've ever looked at a Saturn w/o RKE
Old 12-18-2019, 04:20 PM   #12
Zeebins
Zeebins's Avatar
Went to the junkyard this morning to grab an electric latch. I thought I would have to grab some wiring for it too but apparently I already have the connector for it. I had always wondered why my mechanical trunk latch had an electrical connector on it. Apparently itís for nothing, lol. I will have to add the wiring from the trunk loom onward though.
Powered by Plastic
Old 12-20-2019, 12:39 AM   #13
98_Gold_Uranus
98_Gold_Uranus's Avatar
When I got my 98 it only had a manual lever release for the trunk latch, even though the key fob had the button to open the trunk... I got an electric latch off a 97 and bolted and plugged it right in, worked great. One of the best bolt-on's I've done to the 'ol girl lol
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-26-2019, 11:17 PM   #14
TomM96
Could be a Sensor to indicate if the latch is ajar -- both '97&2000Sws had electric release, and a sensor which illuminates IP bulb, when hatch open, or gate latch ajar.
Add to TomM96's Reputation
Old 12-27-2019, 12:39 AM   #15
Zeebins
Zeebins's Avatar
Originally Posted by TomM96 View Post
could be a Sensor to indicate if the latch is ajar -- both '97&2000Sws had electric release, and a sensor which illuminates IP bulb, when hatch open, or gate latch ajar.
I forgot about that. It's not a feature on SL or SC but it would explain why there is two grounds. I'm guessing that one of the grounds opens with the hatch open, causing the light to go on.
Powered by Plastic
1997 SW2 trunk latch question TheJode S-Series Tech 2 07-07-2019 10:52 AM
95 sl1 trunk latch release and trunk lock cylinder broken. whoodiestyle S-Series General 2 02-01-2014 04:21 PM
Trunk Latch bryanb S-Series Tech 2 11-06-2008 07:51 PM
Trunk Latch on 96 SC2 sandcastle S-Series General 3 09-09-2007 06:00 PM
New trunk won't latch muzikmann S-Series Tech 4 12-14-2005 07:07 PM
