Old 12-11-2019, 07:20 AM   #1
Jef1qr
Jef1qr is a glorious beacon of lightJef1qr is a glorious beacon of lightJef1qr is a glorious beacon of lightJef1qr is a glorious beacon of lightJef1qr is a glorious beacon of light
Default 93 SL2 Master cylinder port sizes.
I see the specs on Rock auto that the primary ports use M13 x 1.5 and the
Secondary uses m10 x 1.0.
I need to TAP the M13 port because I ruined its threads.
I assume you use a M13 x 1.5 tap ?
Home Depot etc sells m12 and m14. Everyone seems to skip M13.
Primary- m13 x1.5 , m11 x 1.5
Add to Jef1qr's Reputation
Rate the quality of this post and help Jef1qr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jef1qr is offline   Reply With Quote
Old 12-11-2019, 09:14 AM   #2
Default Re: 93 SL2 Master cylinder port sizes.
Most places charge $35 to $121+ for that tap, and you would be better just replacing the master cylinder, however;
Ebay has one for about $13, but it comes from England and shipping time is long.
https://www.ebay.com/itm/GENUINE-DRA...AAAOSw5Xpb7G1V
SO, this one is $26 and ships out from CA, not knowing where you live tho.
https://www.ebay.com/itm/M13-X-1-50-...wAAOSwR-9dvdvH
OR, put a helicoil in it for a whole lot less time and money. Check with your local auto parts store nearby.
Old 12-11-2019, 09:56 AM   #3
onlinebiker
Problem is - by the time you get threads cut full purchase - the fitting will not be long enough to tighten.
Replace the MC.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 12-11-2019, 10:15 AM   #4
Rock Auto has a closeout for $23.84 including reservoir. How do you tap it without damaging the seal in the MC or contaminating it with chips?
I vote new or junkyard MC. $17 at LKQ.
Add to Waiex191's Reputation
Old 12-11-2019, 11:42 AM   #5
Jef1qr
I found on amazon for 16.98.
Delivery next day.
I guess Iíll give it a shot. Of course it had to be tge more rare
Size M13
Old 12-11-2019, 10:43 PM   #6
Awesome. I always thread brake lines in by hand. Easy to get them cross threaded if the lines are bent off a little bit. Keep tweaking the brake lines until you can run the nuts home by hand. Leave the wrench for the final torque.
Old 12-11-2019, 11:45 PM   #7
B....bu ....but these tools are so fine and fits like a glove........
Old 12-12-2019, 05:02 AM   #8
Jef1qr
Its only the FIRST thread in port that has been flattened.
I only have to run the tap 1 turn maybe. And Iíll do it with the MC upside down so nothing falls inside. Then wipe it out just in case.
Old 12-16-2019, 05:10 AM   #9
Jef1qr
Hi.
I know some cars are different. But what Order should this. Car be bled ?
Each wheels brake line goes Directly to master.
No proportional valve.
Old 12-16-2019, 08:23 AM   #10
I usually do furthest to nearest. Not sure it is super critical. I also bleed the MC. I block off the ports at the MC with my finger. This is done with the line disconnected That acts as a check valve. Pump the pedal a couple times and it will be bled. It's messy.
Also I find that I go around the car twice. On the first pass the pedal is so soft you can't tell how much good you have done.
Old 12-18-2019, 11:49 PM   #11
TomM96
On any 25 year-old vehicle I'd renew the MC as a matter of course, unless it was a one-off without any replacement.
My experience with a couple of the '90s GM aluminum MCs is that they Are rebuildable when they only have 150-175kMi, however.
Add to TomM96's Reputation
Old 12-19-2019, 03:29 AM   #12
onlinebiker
Originally Posted by Jef1qr View Post
Hi.
I use a separation tank and a vacuum pump....
So it really doesn't matter what order it's done.
I do it with the car on the lift with all four wheels off.
It's the easiest way.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
clutch master cylinder/slave cylinder recommended replacments help A2Saturn S-Series Tech 5 03-01-2019 12:11 AM
Master cylinder port sizes hikeriman24 S-Series Tech 1 03-19-2015 01:26 PM
CLutch master cylinder/slave cylinder azwesjr S-Series Tech 1 12-26-2013 10:26 AM
Oddball nut sizes on master cylinder? bountyhunter S-Series Tech 8 01-19-2012 08:10 PM
CLutch master cylinder/slave cylinder removal Tjflow S-Series General 7 02-17-2010 05:43 PM
