Old 11-20-2019, 11:24 AM   #1
onlinebiker
Default weirdness
The other night I came back from hunting and my SO informed me that our 97 SL2 was doing something weird.
With the ignition off the display on the stereo was still on. I pulled the radio fuse (pass inside) and the lights on the stereo stayed on. I disconnected the battey and the lights turn off. Reconnect the battery - and they stay off. it has not repeated.
Today she drove the 97 SC2 - and when she got to work -the stereo lights stayed on. (different car if you missed it).
what the hell?
I'm stumped..
one of you jokers messing with me?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-20-2019, 12:26 PM   #2
billr
Default Re: weirdness
Bear with me, I am talking about "weird" stuff to try un-stumping you.
Are the stereos both the same? OEM or aftermarket?
Does she have a big wad of keys hanging on both switches?
Have you watched to see how she turns the key to the off position?
Hey, at least I didn't post pictures of an SL and SC and ask if you could identify which is which!
Add to billr's Reputation
Old 11-20-2019, 12:48 PM   #3
onlinebiker
Attention Re: weirdness
lol
both are aftermarket - and both had been functioning correctly for over a year. (several years for the SL2)
No wads of keys. broke her of that habit. 1 key on a small fob.
I got the same results myself messing with the key of the SL. Dunno about the SC2 - she still at work....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-20-2019, 02:18 PM   #4
Is it only the stereo displays that gets power, or can you play music from them?
Any other accessories work, like power windows?
maybe one of these will help?
https://exemplore.com/wicca-witchcra...r-the-beginner
http://www.usccb.org/prayer-and-wors...s/exorcism.cfm
Old 11-20-2019, 04:06 PM   #5
bumpdraft
bumpdraft's Avatar
1998 SW2
When you unlock a dirty car, the key picks-up grit and road salt. Then, you immediately put it into the ignition. I think this is one reason why cars used to have a separate door key.
Add to bumpdraft's Reputation
Old 11-20-2019, 04:45 PM   #6
When this occurs again, try turning on the radios (with ignition off). Try wipers, turn signals. All three should not have power with ignition off.
If this continues, I'm not sure if vehicle exorcism exists.
Old 11-21-2019, 08:59 AM   #7
onlinebiker
I took the "caveman" approach - and ripped the stereo out of the dash. Tonight when the SO gets home - I will stick a stock radio in. I plugged one in - and it worked.
Later I may sacrifice a goat or something...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-21-2019, 10:33 PM   #8
ZuluKono
ZuluKono is on a distinguished road
2000 SC1
Was she listening to Rob Zombie or Ozzy Osbourne?
All GM, all the time.
Add to ZuluKono's Reputation
Rate the quality of this post and help ZuluKono reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ZuluKono is offline   Reply With Quote
Old 11-22-2019, 02:25 PM   #9
onlinebiker
she wouldnt...
but I would..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-27-2019, 01:12 AM   #10
TomM96
On my '97 i decided to renew the IgSw (electrical, not cylinder) because
the starter solenoid never engaged with enough zip. (It helped ... the degradation ceased).
During the last couple months of service from the old IgSw, some aspects of the electric system varied. My favorite, was that sometimes i could operate the radio when the IgSw was not positioned 'Ignition-ON'.
After renewing the IgSw, the radio only functioned when the key was in Ig-ON.
Soooo I think that as switch wears, the contacts move a little, and strange things occur....
Add to TomM96's Reputation
Old 11-27-2019, 01:07 PM   #11
Originally Posted by onlinebiker View Post
she wouldnt...
but I would..
Saw Ozzie at Wings, way back when Randy Rhoades was still alive. . . so. . . much . . second-hand . . smoke
Old 11-27-2019, 06:12 PM   #12
onlinebiker
I did a bunch of concerts at Wings back in the late 70s... We sold tickets at the music store I worked at (Grinnels) and we got comp tickets, stage and backstage passes.....
Saw Ozzy with Black Sabbath at Devos Hall... Great concert.....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
A/C Weirdness KJDS Ion General 2 06-22-2016 08:14 AM
RKE weirdness SteveWoz Astra General 2 03-01-2014 05:35 PM
UP6 Radio Weirdness dennis264 S-Series Tech 4 07-06-2010 11:09 PM
Sky A/C weirdness Bulwark Sky Tech 12 09-28-2009 06:27 PM
WOW more weirdness from my car ad198592sl2 S-Series Tech 1 10-14-2005 10:55 AM
