Old 10-28-2019, 08:40 PM   #1
Homecoming1999
Homecoming1999 is on a distinguished road
Default Life span of water pump.......?
So, my 1999 is 20 years old, and to my knowledge it has the original water pump. Am I playing with fire, or should I just get it changed...Is it possible the replacement one will not be as good as the original?
Brand recommendations?
regards,
Jason
Add to Homecoming1999's Reputation
Rate the quality of this post and help Homecoming1999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Homecoming1999 is offline   Reply With Quote
Old 10-28-2019, 09:08 PM   #2
Pitcher
Pitcher's Avatar
Default Re: Life span of water pump.......?
Usually, on average, about, 80-90k. Some more & some less.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-29-2019, 12:22 AM   #3
Waiex191
Waiex191's Avatar
My '99 went 204,067 or so. My '98 may or may not have the original, and it has nearly 175K.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-29-2019, 09:19 AM   #4
trottida
trottida's Avatar
regards,
Jason
They usually give some pretty good "tells" before they fail completely. Weeping coolant and/or a squeak noise. I wouldn't worry about it but do keep an awareness of it. There are some good replacements out there. I used Bosch when I replaced mine in the 2001 SL1. That was several years ago and the car had well over 350K km on it at the time.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-29-2019, 01:50 PM   #5
This is why I try and post stuff on the What did you do . . . thread.
Easy reference for the dates, though I should try and remember adding mileage. I also documented in my notebook but those are inside the respective cars
  • On my '98 SL2, replaced the water pump Jan 2013 with a GMB from Advance Auto. Mileage would have been about 135k or so; still in the car which now has 201k miles
  • On my '02 SC2, just (end of September) replaced with Valucraft Serpentine Water Pump AVC-844 from Autozone (nobody else had anything in stock nearby); Car would have had about 145k miles
Both times, was made aware by coolant leaks.
Old 10-29-2019, 06:03 PM   #6
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Can guarantee new part will not last as long as the OE one... . Having said that, got 240,000 from original one, and now another 100,000 on the NAPA replacement.
Like to get Delco/GM replacements when possible, and NAPA when I can't. Always look for lifetime warranties, which I hope means something more than one with a 1-2 year replacement warranty.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 10-29-2019, 07:26 PM   #7
trottida
trottida's Avatar
Most times it is the same part in the box and they just surcharge to cover off any warranty replacements. Most owners will not keep the receipt, forget about the warranty or sell the vehicle before having to invoke the lifetime warranty.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-30-2019, 03:31 PM   #8
hholbein
1997 SW2
I replaced my OEM one around 100K miles -- the bearing was making a racket and the pulley was wobbling slightly -- but no leaks.
Replacement was a $20 Gates unit (41024) on Amazon. Very close to the OEM design with good to better build quality.
But unless you're draining coolant anyway, for a thermostat swapout or radiator replacement, I'd just keep driving with the one you have unless it is kickin' up a fuss.
Add to hholbein's Reputation
Old 10-30-2019, 04:37 PM   #9
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
The water pump is usually not one of those "play with fire" parts. It usually starts leaking enough where you'd notice the smell, see the fluid, or at least see the coolant light come on.
That said I'm on my third one. OE changed at 120k, 2nd one changed at 240k or something. It is more of an eventuality type part though, so you could pick one up cheaper online if you plan in advance. I seems to always parts "right away" as there is no plan B for my ride, and end up going with whatever I can get from whatever store happens to be open.
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 10-30-2019, 05:15 PM   #10
Jon Boy
Jon Boy has a spectacular aura aboutJon Boy has a spectacular aura aboutJon Boy has a spectacular aura about
Jon Boy's Avatar
I replaced the pump in my 2001 in 2016 at about 117,000 miles. When it went out, it just started leaking and didn't seize up or have any other kind of catastrophic failure, so it wasn't an emergency.
Add to Jon Boy's Reputation
Rate the quality of this post and help Jon Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jon Boy is offline   Reply With Quote
2.2 ecotec life span 2.2ecotec L-Series General 20 02-05-2018 05:32 PM
LCA questions- life span MikeNW S-Series General 2 03-31-2014 09:01 PM
Water Pump Life Expectancy TXSaturn02 S-Series General 32 09-14-2009 11:12 PM
Radiator life span ?? awh100 S-Series General 24 04-18-2008 10:26 PM
Alternator life span? bender S-Series General 18 02-15-2007 09:32 PM
