Old 10-24-2019, 08:46 AM   #1
datlas
datlas will become famous soon enough
Default 1998 SL Water in Trunk
Original owner 1998 SL, 178K miles.
I just noticed that there is some water pooling in the trunk, in the depression behind the rear wheels. There was about 1 inch on the driver's side, and just some moisture on the passenger's side.
I don't know if this is a leak from the trunk, or if it's getting splashed up from the underside, and at this point it's just a nuisance. I let it dry out and will keep an eye on it.
Any "Usual Suspects" to check for the cause?
Add to datlas's Reputation
Rate the quality of this post and help datlas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
datlas is offline   Reply With Quote
Old 10-24-2019, 09:17 AM   #2
trottida
trottida's Avatar
Default Re: 1998 SL Water in Trunk
Unibody seam sealer under the left and right fender panels below the rear window has failed. This is pretty common and the fix requires removing the fender panels and resealing the seams.
You could drill a drain hole to let the water escape but in the long term this is not a good solution.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-24-2019, 09:24 AM   #3
My '98 has 3 drain holes. Excellent short term solution.
Add to Waiex191's Reputation
Old 10-24-2019, 09:30 AM   #4
datlas
I will investigate both options. I really want to keep the car forever (I am original owner!!) but my wife is really on my case to pitch it the next time it needs any repair (or even maintenance) costing over say $500, so my guess is I will only have the car for another year or two.
Given that, drainage hole is likely my best bet. Just drill in the lowest spot in the well?
Old 10-24-2019, 10:24 AM   #5
Fixing it yourself is pretty low cost. Haven't done it on a sedan, but have read that there is a richpin video - just a bunch of 10mm head bolts, mostly. I think you have to remove the tail light cover (2 screws) and slide the bumper off (some pushpins) plus 3 (?) screws holding the splash panel / fender liner
There's another thread somewhere on the best seam sealer to use, think it was around $8~15?
Old 10-24-2019, 11:24 AM   #6
Yep. Don't forget the spare tire well as well.
Old 10-24-2019, 06:27 PM   #7
hholbein
+1 on the seam sealer failing.
In my SW2, the source of leaks in the cargo area/trunk have been seams leaking:
1) seams behind the rear tail lights -- rain fills up the side pockets on the outside of the rear trunk rails on either side of the mini-spare
2) roof seams near the tailgate hinges
In my case, cleaning the seams and thickly smearing clear silicone over the seams has lasted for 10 years or so.
Add to hholbein's Reputation
Old 10-25-2019, 09:37 AM   #8
Saturn Night
I drilled holes for drainage, as the seam sealer under my rear quarter panel was cracked and rotted out.
Old 10-25-2019, 01:15 PM   #9
Claybury
Claybury's Avatar
If the car has a sunroof also check that the drain tube grommets have not come out from the trunk wall leaving the tubes to drain into the trunk.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
Add to Claybury's Reputation
Old 10-28-2019, 05:55 PM   #10
MikeNW
MikeNW's Avatar
1997 SL
Not a hard job to fix the unibody seams below rear window, I've done this to my 97SL and my brother in law's 00(?)SC. Just need some patience and a dry day or 2. A hair dryer or heat gun will help dry out, between the sheet metal layers.
08 Burgman 400
Add to MikeNW's Reputation
1998 Saturn sc2 water leak in trunk vikasevan S-Series Tech 5 03-31-2014 04:04 PM
1998 SC2 Trunk Light eb121209 S-Series General 3 12-31-2013 02:06 AM
1998 SL-2 Trunk Latch satsl2 S-Series General 0 08-14-2009 10:01 PM
Water in the trunk - 95 SC2 toadson S-Series Tech 1 04-13-2009 09:41 PM
ION 3 2.4 gets water in the trunk Island_Tom Ion Tech 16 06-06-2008 01:34 PM
