Old 09-11-2019, 11:24 PM   #1
ErikS
ErikS is on a distinguished road
1999 SL1
Default wheel bearing dilemma
Picked up a 2002 SL a few years ago - 50K miles - Carfax report clean - but the undercarriage is much more rusted than my 99 SL1 with 265K (both cars from same winter salting latitude).
Installed reman front calipers/pads/rotors at 53K, and at 57K bearings started making noise. Replaced both front bearings, and all was good for 10K miles, when bearing noise started again - increasing pitch with rpm. On turning left, noise went away - which indicated left front bearing was the culprit. Swapped out left front bearing again - but after bearing change the noise still remains - still going away when turning the wheel left at speed. Don't think I messed up on the install, and am flummoxed (changed original bearings on the 99 at 216K, and they're still fine at 265K, so can't imagine I screwed up two bearing changes in 10K miles).
Could the rear wheel bearing have the same sound pattern when bad?
Could anything besides a left bearing make noise that increases in pitch with speed and goes away when turning wheel left?
Suggestions?
Add to ErikS's Reputation
Rate the quality of this post and help ErikS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikS is offline   Reply With Quote
Old 09-12-2019, 07:48 PM   #2
hholbein
1997 SW2
Default Re: wheel bearing dilemma
What brand bearings did you use during the replacement? I think the consensus here is that SKF is the best when it comes to QC, and that buying the hub kit makes most sense -- SKF BR930156K.
Others claim to have had good luck with Timken bearings. Other brands, not so much -- with many, many failures returning in the first 30K miles, which is pathetic and a waste of your time & money in the end.
Also, depending on how poorly the right front bearing was made, it could be a race on that side is messed up.
Add to hholbein's Reputation
Old 09-12-2019, 11:25 PM   #3
billr
Yeah, it could be the RF, or either of the rears. There is no perfect correlation between which way you are turning and which bearing it is that stops making noise. When you turn, the loading on all four wheels changes. The other bearings are less likely, but still must be considered.
Add to billr's Reputation
Old 09-13-2019, 05:13 AM   #4
onlinebiker
CV joint or carrier bearing.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-14-2019, 11:01 AM   #5
hholbein
1997 SW2
ETCG has a video on isolating wheel bearing noise:
https://www.youtube.com/watch?v=cdRpnK5MGQ8
Old 09-15-2019, 02:40 AM   #6
ErikS
1999 SL1
Thanks all. When I did the bearings on the 99, installed Timken bearings with the Autozone hubs. For the 02, used the Autozone Duralast DL518514 kit (prob should have used Timkens there as well). Used the OTC HubGrappler for all bearing changes to date as I don't have a hydraulic press. Pushing the factory bearings out of both the 99 and 02 knuckles was not a problem, but on this last bearing change, the Duralast bearing fell apart, with the race staying stuck in the hub. Had to go to pick-n-pull to get another knuckle from an 02 to finish the job. Guess I gotta now try replacing the right front bearing also - and will be using either the SKF kit, or a Timken bearing.
Old 09-19-2019, 04:13 PM   #7
Saturn Night
www.car-part.com to source used knuckles. The original bearings were SKF or NSK.
Timken is made in China, now. You get what you pay for.
Replacing the spindle is easier than pressing the bearing in or out.
Old 09-29-2019, 10:32 PM   #8
S-forever
S-forever is on a distinguished road
1991 SL2
I had a bad rear bearing that had the same exact effect as a front one when cornering. I could never localize it until it got really bad and then it became obvious. The rears get corroded in place on cars from the rust belt, but popping one out on a southwest car is easy. I just swapped in a pick n pay hub and called it good.
Add to S-forever's Reputation
Rate the quality of this post and help S-forever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S-forever is offline   Reply With Quote
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 08:56 PM
Bad wheel bearing AGAIN? vettegofast Vue Tech 19 06-27-2012 12:51 PM
Wheel Bearing (which one?) jimpennjr Vue Tech 7 03-26-2011 12:12 AM
Wheel Bearing? rickystarshine Ion Tech 2 01-08-2011 12:54 PM
Wheel bearing noise that isn't the wheel bearing? shelby987 Vue Tech 0 06-23-2010 11:16 PM
