Old 08-27-2019, 11:05 AM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default TB crud in SOHC cars
What is the source of most of the crud on the throttle body.
Is it that vent hose from the valve cover-to-air snorkel.
Or from the PCV hose.
08 Burgman 400
Add to MikeNW's Reputation
Old 08-27-2019, 03:07 PM   #2
Default Re: TB crud in SOHC cars
Crud and dirt on the exterior of throttle bodies are from either normal airflow and exhaust leak swirling around and pcv leaks to coat throttle body and engine. Any oil leaks from power steering, coolant leaks, etc, eventually coats everything and collects dirt. The interior of throttle bodies collect crud from pcv combustion byproducts recycled into the intake manifold. When the engine stops, momentum from pcv pressure doesn't come to an immediate stop resulting in coating everything behind the throttle plate in oily black crud - the combustion byproducts from the crankcase.
Old 08-27-2019, 03:11 PM   #3
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
^^What he said.
If you want to prevent it, you run a catch can / oil separator.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 08-27-2019, 04:45 PM   #4
MikeNW
MikeNW's Avatar
1997 SL
I was unclear in the OP. I meant the inside of the TB.
So a catch jar + hoses (which I have) should be on the PCV circuit? Not the other breather hose.
08 Burgman 400
Old 08-27-2019, 05:50 PM   #5
ErikTande
ErikTande's Avatar
https://www.lsxmag.com/tech-stories/...oil-separator/
^^how they work
You would want the can connected to both lines, so you would need a 3 port can (or just "T" the lines). Both ports on the valve cover go to the can inlets, and vacuum to the outlet port. I'd use the vacuum line on the intake manifold and just plug/cap the line on the intake snorkel.
A two port separator would works as well, you just "T" the vaccum lines together. Either way works just fine.
Something like this:
I replaced a dohc cars trans with a sohc cars trans... Now i have problem Scamp707 S-Series Tech 5 06-06-2016 08:18 AM
Creeping Crud MiSaturn S-Series Tech 7 10-22-2014 05:37 AM
runs like crud now.....lol 96sl2-97sl1 S-Series Tech 1 05-17-2009 05:29 AM
Carbon and crud Av8r S-Series Tech 0 04-10-2005 03:01 AM
car runs like crud tko S-Series Tech 3 10-10-2001 08:41 AM
