Old 05-10-2019, 11:40 AM   #1
rubberband man
rubberband man is on a distinguished road
Default amient temperature sensor location on 2008 saturn vue
I am looking for the location of the ambient temp sensor location on a 2008 Saturn Vue 4 cylinder. Thank you
Add to rubberband man's Reputation
Rate the quality of this post and help rubberband man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rubberband man is offline   Reply With Quote
Old 07-09-2019, 11:35 AM   #2
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
2008 VUE 2.4L
Default Re: amient temperature sensor location on 2008 saturn vue
In front of the radiators, between the radiators and the bumper skirt. If you look down from the top you can see a tiny thing with 2 wires going into it.
Peter
CURRENT:
08 Vue XE Black 2.4L
07 Ion 3 Savannah Green Metallic 2.4L
04 Ion 2 Berry Red 2.2
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
95 SL2 Lilac Metallic
94 SW2 White
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 07-09-2019, 01:57 PM   #3
hudypete1
2007 ION-3 Sedan
2008 VUE 2.4L
It is in the same mini-wire harness with the hood-latch-closed sensor. Just follow those wires straight down.
One of the wires to the ambient temperature sensor is green, the other is yellow.
I believe that most temperature sensors from other GM cars (at least) will function the same in case you had to go to a junkyard and try to find one, but couldn't find a Saturn vue. For a buddy, we installed one from a Malibu and it seemed to work just fine.
Peter
CURRENT:
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
94 SW2 White
2008 Saturn Vue XR 3.6L Power Steering Cooler location phaxmohdem 2008 Vue 2 11-06-2018 07:22 AM
2008 Saturn Vue Purge valve canister solenoid location iobrien Vue Tech 10 08-11-2016 12:40 AM
2003 Saturn Vue Ambient Temperature Sensor Gubler Vue Tech 3 05-22-2013 01:42 PM
Outside Air Temperature Sensor Location? ud503j Vue General 3 08-24-2006 10:24 PM
ECTS Temperature & PCM coolant Temperature sensor Matt_Agate S-Series General 6 02-03-2006 08:16 PM
