Old 01-17-2018, 09:57 PM   #1
Gnarkill333
Gnarkill333 is on a distinguished road
2000 SL2
Default Swapping a 97 sc2 dohc into a sohc s chassis??? How?
Ok so my sisters car was clipped by a snow plow last night and the driver side is ruined. The engine still runs great and barely burns oil. Ripped the wheel back. There’s a few cars in my series that have blown up motors. But they are all single cam. What do I need to do to swap the dohc into the sohc chassis? Hers is a 97, and there is a 99 sc1 that looks identical to hers and a few 95-2000 sc1 / sl1 cars for sale.
Need to know ASAP
Otherwise if you are in the Midwest/Wisconsin area I have a smoking deal for you for a great engine!!!
Add to Gnarkill333's Reputation
Rate the quality of this post and help Gnarkill333 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gnarkill333 is offline   Reply With Quote
Old 01-17-2018, 11:14 PM   #2
Default Re: Swapping a 97 sc2 dohc into a sohc s chassis??? How?
Others will chime in, but i'm sure you need to swap everything that the DOHC engine has...bcm/pcm, harnesses....etc.
Old 01-18-2018, 01:11 AM   #3
To put a '96-'99 DOHC into a '96-'99 SOHC...you swap engines, PCM and exhaust from the engine to the cat-con. That's all, if it's a 5spd. If it's an automatic you also have to swap to the DOHC's automatic otherwise you end up with, at best, a 1-gear-wonder transmission.
If swapping from '96/'97 to '98/'99 you have to keep the fuel rail that belongs in the car and keep the DOHC injectors with the DOHC engine.
Unless a '00-'02 engine is under $100 with a 10 year no-questions-asked guarantee, it's not worth the hassle of putting into a '91-'99.
Swapping 96 SOHC engine into a 1996 DOHC car ErikTande S-Series Tech 15 07-25-2016 02:16 PM
Swapping Engines DOHC to SOHC jhart L-Series Tech 1 08-31-2013 11:22 AM
swapping SOHC for DOHC soupedupsaturn S-Series Mods 3 09-29-2011 06:19 PM
Question about swapping from a sohc to a dohc...... lonewolfncubs S-Series Mods 10 06-05-2010 01:42 AM
head swapping sohc to dohc joe's95sc1 S-Series Tech 0 03-28-2004 09:52 AM
