Old 01-20-2013, 05:24 PM   #1
golftango
golftango will become famous soon enough
golftango's Avatar
Default Clean camshaft sensors - 2.4 L
If anyone has experienced a loud knock or scrape sound @ startup may try cleaning their intake and exhaust cam sensor assemblies.
They are located on the far left hand side on top of the engine. Remove the engine cover and you will see them.
They are held on by 10mm bolts. I removed them and soaked them in parts cleaner up to the rubber o-ring. The screens were a little dirty, but nothing too bad.
I then sprayed them off with electronics part cleaner to remove any residue and let them dry.
Lastly I filled a small cup with 5/30 oil and dipped them to the o-rings making sure oil filled each one.
I then reinstalled them being sure not to over tighten. Both the sensors and head are labeled INT for intake and EXT for exhaust.
I did notice the subsequent starts were more quiet, need to wait and see if there is any grinding or slamming on startup anymore.
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 01-21-2013, 01:40 PM   #2
golftango
golftango's Avatar
Default Re: Clean camshaft sensors - 2.4 L
Edit: I did mean Camshaft Position Actuator Solenoid , not just "sensors".
Old 01-21-2013, 02:49 PM   #3
cola
cola is on a distinguished road
cola's Avatar
2009 AURA XE
1996 SL
I'm glad you posted this. My Aura just recently starting making a noise similar to what you described. I will have to take those out and clean them.
Thanks!
David
2009 Aura XE 2.4-----SOLD
2004 Vue 3.5 AWD
1999 SL2 Auto
1998 SL2 5-Speed------SOLD
1996 SL1 5-Speed
Add to cola's Reputation
Rate the quality of this post and help cola reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cola is offline   Reply With Quote
Old 01-21-2013, 04:03 PM   #4
golftango
golftango's Avatar
Thanks!
David
I'm going to see if cleaning them will solve this. If not, I'll just replace them as they are only $30 or so each.
Old 05-03-2013, 12:41 AM   #5
Logansdaddy
Logansdaddy is on a distinguished road
2009 AURA XE
My '09 Aura XE 2.4L threw out this code last summer, shortly after I bought the car from a dealer...and after the very short warranty expired. The Check Engine light will come on and stay on for days, then not light up for a while, then come back on, etc.
I do know where, and how to replace the sensor, but if it's anything else like a solenoid, then I'm clueless as to how to find and fix it myself. I'd like to do it myself and save some money...and learn something!
My engine sounds like it needs to shift, yet it shifts just fine.
Thanks for any help and advice!
Add to Logansdaddy's Reputation
Rate the quality of this post and help Logansdaddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Logansdaddy is offline   Reply With Quote
Old 05-03-2013, 11:14 PM   #6
greenman
greenman is a jewel in the roughgreenman is a jewel in the roughgreenman is a jewel in the rough
2009 AURA XE
Originally Posted by Logansdaddy View Post
My '09 Aura XE 2.4L threw out this code last summer...
which code?
Add to greenman's Reputation
Rate the quality of this post and help greenman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greenman is offline   Reply With Quote
Use Saturn oem O2 sensors or generic sensors? 2strkBlu S-Series Tech 25 08-09-2016 02:55 PM
Camshaft sensor yardmaster S-Series Tech 11 10-25-2010 10:19 AM
How to tell if a camshaft is bad? Growser S-Series Tech 42 02-10-2009 12:16 AM
Camshaft Sensors musicman2005 S-Series General 7 03-12-2005 07:24 AM
Camshaft upgrade sspriest S-Series Tech 1 05-26-2001 11:14 PM
