Old 04-12-2018, 11:37 PM   #21
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2009 AURA XR
2005 ION-3 Sedan
Default Re: Aura remote start?
Ok it did turn on the parking lights, but the car didn't start.
Is there a dedicated fuse for the remote start?
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 04-13-2018, 07:05 AM   #22
imaddicted2u
imaddicted2u will become famous soon enough
2008 AURA XE
Found this...Hope it helps...not sure about a fuse, but it's doubtful.
If the check engine light is on or the fuel level is low, the remote start will not work. As well as:
A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
The vehicle is in valet mode. (not sure Aura has Valet mode)
More than 2 remote starts have been attempted.
The hazard switch is in the ON position.
A current hazard switch DTC is set.
The vehicle hood is ajar.
A current hood ajar DTC is set.
The CTD system detects an alarm trigger.
Excessive engine RPM
Excessive coolant temperature
Accelerator pedal position greater than 0 percent
Vehicle not in Park
Vehicle theft deterrent malfunction
A current automatic transmission shift lock control system DRC is set.
A vehicle speed sensor signal is detected by the ECM.
Check it with a scan tool and it will tell a reason that the remote start is disabled. but to check this, you need a scan tool that can read the Body Control Module Data.
The Hood switch has 3 wires to it and the black wire is a ground and the purple wire should get grounded when the hood is closed and the pink wire should be grounded when open.
Old 04-13-2018, 10:28 AM   #23
SL2 Ride
2009 AURA XR
2005 ION-3 Sedan
Thanks again, i'll work my way through the list tomorrow when i'm off work.
Old 04-14-2018, 05:02 PM   #24
SL2 Ride
2009 AURA XR
2005 ION-3 Sedan
Turns out I had an engine code being thrown that was not allowing a remote start.
Cleared the code, and it started up.
Interesting side note is that I must have gotten an early production Dorman set, and the battery is nearly dead.
Well I got an alert in the trip odometer area that alerted me to the battery being low.
Old 04-14-2018, 07:51 PM   #25
imaddicted2u
2008 AURA XE
Glad to hear you got it going. I didn't know about the remote low battery notification.
Old 04-21-2018, 01:28 PM   #26
greyXE
greyXE is on a distinguished road
I traded my 2008 XE a while ago, but my Aura (and others according to the dealer) had a "hidden" remote start function.
Although I had a remote without a remote start button, if I pressed the lock button once, the unlock button twice and then the lock button again, the car would remote start. Some here theorized that maybe it was some kind of fleet option, although mine was not a fleet vehicle AFAIK.
Add to greyXE's Reputation
Rate the quality of this post and help greyXE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greyXE is offline   Reply With Quote
Old 05-09-2018, 09:04 PM   #27
SL2 Ride
2009 AURA XR
2005 ION-3 Sedan
Another update on my dorman remote. Three different new batteries, and all 3 get the low battery alert on the Aura dashboard.
So now i'm wondering if the remote is defective, and not using the full battery charge for some reason.
I got a second one i'm going to program in the next couple of days, and i'll see if it does the same thing.
Old 05-09-2018, 09:43 PM   #28
imaddicted2u
2008 AURA XE
Look at the solder joint for the + battery clip. Might be a cold solder joint.
http://www.keylessfix.com/picts/CircuitBoard2.jpg
Old 05-10-2018, 01:00 PM   #29
SL2 Ride
2009 AURA XR
2005 ION-3 Sedan
Haven't had the time yet, but I programmed the 2nd remote and it works with no battery warning.
Saturn Aura Remote Start xlevix10 Aura General 1 04-07-2016 02:47 PM
How to tell if aura has Remote start(without fob) buCKshoTZ Aura General 7 03-21-2014 05:04 AM
Saturn Aura Remote Start dgaugler Community Center 0 11-24-2008 07:22 AM
2-Way Advanced Remote Start for Aura? AuraDrvr89 Aura General 23 06-10-2008 02:45 AM
Remote Start 07 Aura bradt123 Aura General 1 02-26-2007 12:51 PM
