Old 10-19-2020, 08:28 PM   #41
93 SL1 Canada
93 SL1 Canada is on a distinguished road
93 SL1 Canada's Avatar
1993 SL1
Default Re: Need a Front subframe
Originally Posted by Waiex191 View Post
This is from page 9 of my thread.
http://www.saturnfans.com/forums/sho...=234273&page=9
The bolts for the trailing arms screw into captive fasteners. But, when they rust bad enough, they shatter the rust and the nut spins.
It can be welded and repaired, as at least a couple of our intrepid members have shown, in the links I shared. If you are up for it - go for it. If you are not, then once a trailing link breaks you are screwed.
Wow Waiex, those are great pictures from your thread. I've never seen a bolt removed by drilling it like that. Very clever.
93 SL1 Canada is offline   Reply With Quote
Old 10-19-2020, 11:12 PM   #42
93 SL1 Canada
1993 SL1
What is the arm shown in these photos? Should I replace it as well?
Old 10-20-2020, 12:13 AM   #43
Waiex191
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
Waiex191's Avatar
Thanks. Panic is the mother of many inventions.
Regarding the last two pictures, those are the control arms. They are a wear item, not super expensive, and a good thing to replace based on how they look. Plus you will be taking so much stuff apart it would be a shame to not replace them. I made that mistake once.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 10-20-2020, 04:25 AM   #44
454cid
I'd say no..... that's way worse than my car, and I'm wanting to get into something else because of rust.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
Old 10-20-2020, 10:09 AM   #45
93 SL1 Canada
1993 SL1
Okay, thanks. Do I need to go to a wrecker, or can I get them new?
Old 10-20-2020, 10:56 AM   #46
Waiex191
Waiex191's Avatar
You can get them new anywhere. I used Mevotech ones with grease fittings from Rock Auto. Member trottida has also had good luck with them. I am still chasing a clunk and not sure if it is the Mevotech parts. Others have had failures with that brand. I'd probably get Moog next time.
https://www.rockauto.com/en/catalog/...trol+arm,10401
Bryan Cotton
Old 10-20-2020, 05:54 PM   #47
93 SL1 Canada
1993 SL1
Hi Folks, I know it's better to get a Southern US part, but I'm really time-limited here. I need to get a new engine cradle in the car before the snow flies, which could be as early as a week or two. I found on a website two engine cradles which are local: one is a "2001 Engine Cradle/Rear Crossmember Saturn S Series", and the other is "2002 Engine Cradle/Rear Crossmember Saturn S Series". Is the only difference between these and my 1993 the rad mount? Is everything else the same?
Old 10-20-2020, 11:05 PM   #48
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
The transmission dog bone mount bracket is on the subframe on 92/93. It was moved over to the frame rail for 94-02. In theory, the bracket that’s on your current subframe could be removed swapped over to the 94+ subframe. I have no experience doing this but the bolt holes for the bracket should still be there on the 94+ frames.
I’m not sure what your budget is for this project, but if you have the money I would replace the 2 dog bone mounts while the subframe is being swapped. Looking at your pictures, the dog bone mount you currently have is the old design. Saturn switched to the current one in 98. They are probably pretty tired and due for a replacement as well.
Your current radiator will fit, it just may need some zip ties to be securely held in place. You could also buy a 94+ radiator and not have to worry about the mounting problem. (The a/c condenser will also have to be replaced if you do go this route)
97 SL2, auto, 121K miles
Old 10-20-2020, 11:41 PM   #49
93 SL1 Canada
1993 SL1
Originally Posted by Zeebins View Post
the bracket thatís on your current subframe could be removed swapped over to the 94+ subframe. I have no experience doing this but the bolt holes for the bracket should still be there on the 94+ frames.
Okay. If the bolt holes for the bracket aren't there on the 94+ subframe, could the bracket be welded on, or would that be a safety risk?
Is the dog bone the same as the control arm? I located new control arms on RockAuto. But if I buy a 2001 or 2002 engine cradle, should I buy control arms for that year (instead of 1993), and if I do, will they mount properly at the other end?
Thanks!
Old 10-20-2020, 11:56 PM   #50
Zeebins
Zeebins's Avatar
If the bolt holes aren’t there you could just drill them yourself. Welding would also work, but it would be much harder to remove again in the future if needed.
This is the dog bone mount, also known as the torque strut mount. https://www.rockauto.com/en/catalog/...rut+mount,5556
Control arms are the same for all S-Series, so it won’t matter which year you buy them from
Old 10-20-2020, 11:59 PM   #51
Waiex191
Waiex191's Avatar
I would not be concerned with welding or bolting the old dogbone bracket onto your new subframe. The dogbones are not the same thing as the control arms.
Dogbones are properly called torque strut mounts.
Bryan Cotton
Old 10-21-2020, 07:42 AM   #52
trottida
trottida's Avatar
I'm surprised nobody has commented on the dogbone; it looks to be bent. The center section is usually straight.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 10-21-2020, 10:27 AM   #53
93 SL1 Canada
1993 SL1
If the newer subframe lacks a mount for the dogbone bracket, what can I do about this?
Thanks!
Old 10-21-2020, 10:47 AM   #54
93 SL1 Canada
1993 SL1
Thanks!
Has anybody out there put a newer subframe in a 92-93 SL1? How did you mount the transmission dogbone?
Old 10-21-2020, 10:57 AM   #55
Zeebins
Zeebins's Avatar
I was about to say that that’s just how the first design mounts are, but you’re right. It is supposed to be straight. I’ve seen others with a bend like that before so I just assumed it was normal. Guess the aluminum gets soft over the years, or just can’t handle the torque like steel can.
http://www.evilplastic.com/mounts-a.htm
Old 10-21-2020, 04:34 PM   #56
waiter21
2003 VUE 2.2L
When I replaced mine on my Vue a couple years ago, I went to Texas and got one. zero rust.
http://www.saturnfans.com/forums/sho...d.php?t=234668
This fall I repaired the rusted out front cradle mounts.
http://www.1999southwind.com/toad-20...#ENGINE_CRADLE
Old 10-21-2020, 10:05 PM   #57
93 SL1 Canada
1993 SL1
I was about to say that thatís just how the first design mounts are, but youíre right. It is supposed to be straight. Iíve seen others with a bend like that before so I just assumed it was normal. Guess the aluminum gets soft over the years, or just canít handle the torque like steel can.
I better put a new one in! I'll keep the bent one in the museum.
Old 10-21-2020, 10:06 PM   #58
93 SL1 Canada
1993 SL1
I wish I could drive down and get a rust-free cradle. Unfortunately the border is closed. I will have to have it shipped.... probably cost a lot.
Old 10-21-2020, 10:11 PM   #59
93 SL1 Canada
1993 SL1
Here's some more pictures of the underside.
Old 10-21-2020, 10:13 PM   #60
93 SL1 Canada
1993 SL1
These pictures include the rear subframe (if I am understanding this part correctly).
Need Front subframe (engine cradle) for 1993 SL1 SOHC 4door 93 SL1 Canada Classifieds 1 10-15-2020 05:09 PM
Great Engine - Wrecked front subframe Help! lara1966 S-Series General 13 07-25-2015 09:58 PM
Rusted Front Subframe / Engine Cradle Rivernut Vue Tech 7 03-07-2013 12:59 PM
Replacing Front SUbFrame in 95' SL DevilDogMech S-Series Tech 8 08-14-2007 12:07 PM
wtb front right subframe itsmesillybubba Classifieds 8 01-30-2006 09:39 AM
