Old 10-15-2020, 05:37 PM   #1
93 SL1 Canada
93 SL1 Canada is on a distinguished road
93 SL1 Canada's Avatar
1993 SL1
Default Need a Front subframe
Hi Folks,
My SL1 runs great but the engine cradle is gone. Anybody out there have one?
Thanks,
John
93 SL1 Canada is offline   Reply With Quote
Old 10-15-2020, 07:05 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Need a Front subframe
Try to get one from the southern USA on https://www.car-part.com/
Old 10-15-2020, 07:59 PM   #3
93 SL1 Canada
1993 SL1
Okay thanks, I am trying this!
The website asks me if it is the front subframe or the rear ("Rear SOHC, Rear DOHC") that I need. I didn't realize there were 2 subframes in the engine cradle?
Old 10-15-2020, 09:27 PM   #4
imaddicted2u
2008 AURA XE
Been a while since I had a SL1. I found a drawing, just to make it more confusing, it's listed in one spot as front and another as rear. I can't find any other reference to a "front engine cradle"
https://www.gmpartsdirectonline.com/...G/IB91110.html
I'm thinking you want the Rear one for your engine, DOHC or SOHC.
Old 10-15-2020, 09:30 PM   #5
imaddicted2u
2008 AURA XE
Here are a couple more used parts sites.
https://www.partshotlines.com/
https://www.lkqonline.com/
Old 10-15-2020, 09:53 PM   #6
onlinebiker
Pay attention to the upper transmission mount.
Earlier ones - and if I recall correctly, the 93 - the upper tranny mount - the dogbone attatches to the subframe - wheras the later ones - the dogbone attatches to the frame itself.....
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-15-2020, 10:05 PM   #7
SRGW
1997 SL1
Post Re: Need a Front subframe
http://www.saturnautosalvage.com/
You must call as they will not do email.
1995 SL1 236,300 2005>2018
1997 SL1 85,100 2014>????
CHECK YOUR OIL!!
Old 10-16-2020, 02:18 AM   #8
93 SL1 Canada
1993 SL1
Wow, these are amazing links! Thanks!
Old 10-16-2020, 02:22 AM   #9
93 SL1 Canada
1993 SL1
Okay, so the upper transmission mount is a separate item from the engine cradle?
When I start to add up the number of parts I will need, the list seems pretty big.
Would anyone have a reference drawing for the upper tranny mount?
Old 10-16-2020, 08:03 AM   #10
onlinebiker
Take a look where your current upper mount attatches. Is it on the frame or the subframe?
You need to order one with the same mounting. It should come with it.
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-16-2020, 09:44 AM   #11
There are 2 subframes, 1 for the engine and 1 for the rear suspension.
For '93 there are likely 2 subframes for the engine, it was a changeover year both for the height the radiator mounts and how the upper transmission mount attaches (upper engine mount is always on the passenger fender/wheel well). Sometimes it has a bracket that goes to the subframe, other times it mounts like '94+ to the frame rail.
IMO don't worry about the radiator mount, if you get the high mount and needed the low mount it still clears the hood and O2 sensor; if you get the low mount and needed the high mount it just kinda swings with no factory way to secure it (just get straps from the hardware or car parts store).
Old 10-16-2020, 12:33 PM   #12
93 SL1 Canada
1993 SL1
Wow, thanks! I will examine the upper tranny mount tomorrow when I go to see the car (it's in storage).
As I recall, there were brackets that hold rubber mounts for the ?control arms and ?sway or stabilizer bar. They were all rotten, so I would have to replace them.
Are there mounts that mount the engine to the subframe? Likely I would have to replace all these as well.
Thanks to everyone for your great help!
Old 10-16-2020, 01:39 PM   #13
AutoXr
AutoXr is on a distinguished road
2002 SC1
just the Lower trans mount driverside and dogbone mount passenger side i believe. you can get the whole kit from rockauto pretty cheap, in total there are 4 mounts for the tranny/engine
AutoXr is offline   Reply With Quote
Old 10-17-2020, 11:24 AM   #14
93 SL1 Canada
1993 SL1
Okay, thanks. If I can get to the storage today I will check these things out. Too bad Rock Auto doesn't have the subframe!
Old 10-17-2020, 11:38 PM   #15
93 SL1 Canada
1993 SL1
Got under my SL1 today and took these:
Old 10-17-2020, 11:44 PM   #16
93 SL1 Canada
1993 SL1
More pics:
Old 10-17-2020, 11:46 PM   #17
93 SL1 Canada
1993 SL1
Still more pics:
Old 10-17-2020, 11:49 PM   #18
93 SL1 Canada
1993 SL1
It's amazing how some parts are mint and some are rotten:
Old 10-17-2020, 11:51 PM   #19
93 SL1 Canada
1993 SL1
I'm hoping you folks could comment on the condition and what I need to make it safe:
Old 10-17-2020, 11:53 PM   #20
93 SL1 Canada
1993 SL1
The last 2 pictures are (I think) the upper tranny mount?:
Need Front subframe (engine cradle) for 1993 SL1 SOHC 4door 93 SL1 Canada Classifieds 1 10-15-2020 05:09 PM
Great Engine - Wrecked front subframe Help! lara1966 S-Series General 13 07-25-2015 09:58 PM
Rusted Front Subframe / Engine Cradle Rivernut Vue Tech 7 03-07-2013 12:59 PM
Replacing Front SUbFrame in 95' SL DevilDogMech S-Series Tech 8 08-14-2007 12:07 PM
wtb front right subframe itsmesillybubba Classifieds 8 01-30-2006 09:39 AM
