Old 10-27-2020, 12:44 AM   #61
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: High engine fan speed in cold weather...a brief story...
Iac cannot control the idle speed. Can your code reader give you any readings on the iac position? If it is closing off the idle air bypass port Like it should and there are no vacuum leaks then the throttle plate is letting too much air by. I think 300,000 plus miles things might wear a little. There is a screw probably under a cap that will adjust the throttle plate. I would close the plate some but not enough to get sticky, and see if the idle control will actually work again. You might need to adjust the throttle position sensor also, but I can check. Some readjust with each key cycle.
2002 L200/5 loaded, coming attractions B207R and F40, Ion Redline axles will make this work.
Old 10-27-2020, 02:03 AM   #62
pierrot
pierrot's Avatar
I can't say with certainty, but I wouldn't expect that it does. It's an Innova 3030f, not a very high end reader at all although I do like it.
I'll be on the look out for an adjustment of the throttle plate. I don't recall seeing anything like that when the throttle body was removed from the intake manifold, but since I wasn't looking for that it could easily have been missed. The other thing about this is just how intermittently the event arises. However, the idea that it may have something to do with the throttle plate has some merit as I see it. More often than not, this problem has occurred after very cold overnight temps. During more average overnight temps this was less common to nil. From about mid-April until last week there had been no irregularities whatsoever. Perhaps the cold temperatures caused some contraction in the metal and allowed for more air to pass by the plate. For the time being, it's just conjecture on my part. We'll see as we go along.
340,000 miles - Holy canolli!
Joe Biden for POTUS and Kamala Harris for VEEP. What follows if they get their way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Old 10-27-2020, 10:30 PM   #63
I think you can determine operating temperatures by creating an artificial error - disconnecting a sensor triggering the OBD II self diagnostics into capturing data. Choose a readily accessible sensor, have the engine fully warmed and disconnect a sensor. The check engine light should turn on and capture freeze frame data including coolant temps. Since you know which sensor (tps, iacv, map, etc) is disconnected, the error code should display the appropriate sensor error code. Download this captured data and see what coolant temps are. Reconnect the sensor and either let the OBD II system reset the check engine light or manually reset the error.
Old 10-29-2020, 03:42 AM   #64
pierrot
pierrot's Avatar
Ah, fdryer, what a fine idea. The logic seems quite reasonable and the effort to attempt it is minimal. I like it! Thank you, my friend!!
cold weather starts, lose power to accessories, high volts txvueowner Vue Tech 54 12-11-2016 11:54 AM
High idle issue in cold weather awilson506 S-Series Tech 20 11-25-2014 05:53 AM
92 SL2 oil pressure gauge pegs high in cold weather? Brian Kendig S-Series Tech 6 12-08-2010 12:39 PM
Engine almost stall in cold weather – please HELP hydromech S-Series Tech 7 01-16-2009 07:12 PM
High idle with cold weather jgtatl S-Series General 11 11-06-2004 08:48 AM
