#1 | ||||
![]() Join Date: Feb 2018
![]() HI, Does anyone know the radiator fan operating temperature for a 2008 Saturn Astra H 1.8 L??
My fan does not come on. The temp reached yesterday was 96 degrees and no fan came on no 1400 codes came up as I keep checking. THANKS
#2 | ||||
![]() What does your cooling temperature show for a normal engine? 96F ambient temps is not very hot. If you're in local stop and go traffic, the cooling fan may cycle as coolant temps reach a certain value like 220F. There are several ways to test fan operation starting with checking the fuse for three cooling fan. If ac works, turning on ac should turn on cooling fan - two radiators warm up and warm/hot condenser coil airflow going into the radiator won't help with cooling so the fan is turned on. Check too see fan operation with ac on. Another way to check fan operation is to power the fan directly from the battery.
#3 | ||||
![]() Thanks Fdryer, I do not have air condition, but i shall check the fuses
![]() also wound this be the O2 SENSOR I need as there are 2? Oxygen Lambda Sensor O2 Sensor Probe For Vauxhall Opel Astra H 04-13 855361 && My error code is: ![]() P0141 MIL Controll: Yes Current: NO Historic: Yes Description: Heated oxygen sensor (HO2S) 2, bank 1 heater control circuit malfunction General, Short to Battery ---------------------------------------------------------------------------- Falaut Codes Readed By OPL DTC Reader 2.02
#4 | ||||
![]() Looking up P0141shows the downstream (after the catcon) O2 sensor heater is faulty. Either ther heater has an intermittent connection or it failed. You can try disconnecting and reconnecting it several times and see if the check engine light goes away on its own before replacing it. Car mileage?
#5 | ||||
![]() Thanks .. 125,000 miles I . will get my mechanic to try that.
Thanks again. ![]()
#6 | ||||
![]() ![]() ![]() Join Date: Nov 2008
2009 Astra XR
![]() If you want to go by the computer, which can be seen in the "secret" BC menu, my fan doesn't come on until 99C. HTH
... 2009 Saturn Astra XR3 5-Speed - 75,000KM
#7 | ||||
![]() [B][/B
![]() THANKS, KikAstra
engine stopping after reaching operating temp | taxladyone | L-Series Tech | 5 | 04-30-2013 02:51 PM |
2000 LS2 Thermostat Issue What temp should coolant be at normal operating temp | Bob Panczak | L-Series Tech | 3 | 12-14-2010 01:49 AM |
Question on operation temp. sl2 | Kaveman | S-Series General | 22 | 02-27-2009 11:38 AM |
Operating temp? | papayamon2 | S-Series Tech | 10 | 09-16-2008 02:45 PM |
SES Light turns off once engine is at operating temp...? | bskicrash1 | S-Series General | 6 | 03-23-2006 10:35 AM |
