Old 07-01-2020, 10:17 PM   #81
rochvids
rochvids is a jewel in the roughrochvids is a jewel in the roughrochvids is a jewel in the rough
Default Re: Aura won't crank
I ordered a used computer from ebay that's programmed to the VIN of my car. It is arriving Friday. I can return it within 30 days if needed. I will post back Friday afternoon/early evening.
rochvids is offline   Reply With Quote
Old 07-03-2020, 09:22 PM   #82
rochvids
Part did not arrive today. Should be here tomorrow or Monday.
Old 07-06-2020, 06:59 PM   #83
rochvids
ECU arrived and installed, it fired right up!!
It appeared inputs were working fine but there were no outputs from the computer, thatís why the fuel pump relay, spark plugs, etc. were disabled.
Now I just need to unfreeze the pulleys of the alternator and the A/C compressor.
Thank you so much guys!! This car kicked my ass but your guidance was very helpful along the way.
I hope this thread helps others, thank you again!!
Old 07-06-2020, 08:48 PM   #84
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Awesome news! Who doesn't like a happy ending...
You may be able to get a socket on the alternator pulley holding nut to turn it. I've used a rubber strap wrench to free alternator pulleys before. A chain vise grip might be a good choice if it's really stuck. Probably a good idea to cover the pulley splines with a piece of serpentine belt or rubber. An AC pulley may need to have the AC clutch jumped so it is engaged. Hopefully the compressor is not seized.
Old 07-07-2020, 06:17 PM   #85
rochvids
Thank you!! It felt so good to hear it running
I tried that and any other way I could think of, but it didn't want to budge. I looked inside and I saw why. Somehow snow or water got in there and everything got rusted up. I went to the salvage yard and picked up an alternator that's in a good shape. As for the a/c compressor, I was able to get it to move, the pulley is turning with some slight force but not spinning freely as I think it should. If I put the belt back on and started the engine, would the rotation help free the bearing?
Old 07-07-2020, 07:59 PM   #86
imaddicted2u
2008 AURA XE
When the AC clutch is not engaged the pulley should turn freely. It might free up if you run it with the belt on or it could tear up the belt. Did you try to turn the pulley with the AC clutch relay jumped to see if the compressor can be turned? If the AC compressor is stuck, the belt might be destroyed when the engine is running and computer engages the AC clutch. If the compressor can be turned, I think I would pull the AC clutch relay and start the engine with the belt reinstalled and hope it frees up the pulley. If it does then stop the engine, put the relay back in, start it up and try the AC...while hoping for the best...lol.
Here is a video of an AC compressor tear down, might help to understand what's going on with the clutch mechanism.
https://www.youtube.com/watch?v=urFVLKlpf1I
2008 Saturn Aura 3.6 NO CRANK, NO START when HOT VicSaturnS Aura General 3 08-15-2018 03:59 PM
07 Aura will crank but wont turn -- codes P1057 and P2A04 alexsmithfw Aura General 2 05-11-2017 11:22 PM
Symptom, when warm always have to crank, stop, then crank and it starts 1.9 sohc S-Series Tech 2 07-22-2016 10:39 PM
2007 Saturn Aura crank but no start. Determined187 Aura General 6 03-23-2014 10:22 PM
2000 SL2 Cold Starting Issues [Crank crank crank...] RarestRX S-Series Tech 8 02-12-2012 12:58 PM
