Old 06-30-2020, 07:13 PM   #1
spenser4
spenser4 is on a distinguished road
Default Under hood fuse box replacement
I am working on a 2008 Astra XR 1.8 hatachback 2door. I believe the under hood electrical center took a dump. FYI I does contain logic. I do have GM SPS access and security coed for this vehicle. GM service manual not real clear on UEC replacement. I know I need to use SPS to rest ecu before I remove and replace the uec. It doesn't say when you go through SPS and get access to reset ecm. It has you turn key off. You see programming on Tech 2 win screen. Then states turn key on. You see programming again. I am guessing you turn key off when this is done. Disconnect battery. Replace uec. Turn key back on. Then you have choice. Program ECM. Program CIM Program both. I am guessing you do both. So you can tell the ecm a new uec was installed. Then program cim. SO you can program all lans. Immobilizer Security Info center environment etc. Any help would be great.
spenser4 is offline   Reply With Quote
Under hood fuse block fire CierraSimmons 2008 Vue 0 05-17-2019 11:42 PM
2002 Saturn SL2 under hood fuse block mattwithcats S-Series General 1 10-30-2018 10:42 PM
Under The Hood Fuse Box Chaz9496 L-Series Tech 2 11-15-2017 10:49 PM
09 VUE under hood fuse block schematic gaurdien 2008 Vue 2 02-11-2017 01:52 PM
Fuse Panel (under the hood) Jase Astra Tech 4 07-16-2012 10:41 PM
