Old 08-09-2019, 02:29 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default Those small coolant hoses
1997 SL
As part of the head gasket repair, I also installed new timing set, water pump, and hoses.
After 22 years, I installed those 4 small hoses too. I had some trouble finding them. Ordered from Amazon for about $30 total- compare to big parts stores
Here is a photo, it might help others. They are all Gates hoses. A couple of them are too long but can be cut to fit.
I cut the factory collars off with a rt. angle cutter. Carefully, don't touch the aluminum pipe.
08 Burgman 400
Old 08-09-2019, 04:32 PM   #2
Pitcher
Pitcher's Avatar
Default Re: Those small coolant hoses
Eliminating problems down the road...
Owned 4 other S-Series.
Old 08-10-2019, 12:37 PM   #3
Sid
Sid will become famous soon enough
Sid's Avatar
Thanks for your post. I've had the new hoses sitting in a box for a while but haven't gotten around to putting them on. I did work on the hose in back of the engine for a while and then left it on. It's not real easy to get to. My hoses still look pretty good but they are 23 years old...
It doesn't look like a trivial job. I take it you didn't have to take the aluminum pipe out.
96 SW2 5MT
Sid is offline   Reply With Quote
Old 08-13-2019, 03:44 PM   #4
MikeNW
MikeNW's Avatar
1997 SL
Yes I took out the aluminum pipe. See my photo.
This is possible only if you removed the "front" motor mount and its firewall bracket which I did as part of the recent head gasket repair.
With the head off, and intake manifold out, it's an easy job. Otherwise, probably have to tilt the "power module" forward to get space.
08 Burgman 400
Old 08-13-2019, 03:47 PM   #5
MikeNW
MikeNW's Avatar
1997 SL
Oh, I found the hoses on RockAuto. Under heater section. Not cooling.
08 Burgman 400
Old 08-16-2019, 03:38 PM   #6
Highmile
Highmile's Avatar
When I replaced mine I put the worm drive clamps on these hoses. Every time the weather changed they'd start leaking. I did some junk yard searching and came up with the spring clamps and installed them. No more leaks.
Highmile
'95 SL1 691k and counting
Coolant hoses Tobygot S-Series General 10 09-25-2010 02:34 PM
Hoses, thermostats & coolant. Oh my. :) Kaervak S-Series Tech 6 08-19-2008 09:43 PM
changing coolant hoses? 1993 S-Series Tech 4 02-18-2005 10:09 PM
Coolant hoses Bill Murray Miscellaneous Tech 4 09-26-2003 09:02 PM
coolant hoses rogerk S-Series Tech 3 09-07-2000 10:20 PM
