#1 |
![]() Join Date: May 2000
Have you ever had a defective belt tensioner ? I put a new belt tensioner (black label) and a new idle pulley in. When the A/C is on, I can hear a rattle, I look down and see the belt tensioner moving back and forth quite a bit and I believe it is the source of the noise. Has this occured before???
#2 |
It is possible to get a bad new part. I have never seen it in a belt tensioner but it could happen. What do you mean by black label in referance to the tensioner? The tesioner will have a certain amount of movement in it when the engine is running but if it's more than 1/4 (at most?) then I would certainly suspect it as being bad.
#3 |
My bad, the black label is for the idle pulley. It is moving quite a bit, more then 1/4. The rattle is heard at idle, but is extremly faint, it is more noticeable when the a/c is turned on. could be be?
#4 |
![]() Join Date: May 2002
I'd make sure you didn't contaminate your new tensioner with parts cleaner or any other liquid, they get kinda noisy after that. May want to check your a/c compressor operation for excessive drag/siezed ? that too causes the tensioner to act up and get noisy.
#5 |
Your new belt tensioner may have a weaker spring. What about the belt itself, is it new or same old one?
Also, the rattling you described is it happening during the AC compressor is on, or simply just idling? Also make sure your new tensioner seats properly and tighten correctly, otherwise it'll vibrate as well. |
#6 |
haha, i could be of help here...ive heard this post too many times, so im not gonna read it all...anyway, i still have the problem..check this out...in my car the noise is prominent in idle while in gear...with the a/c on...with the a/c off it rarely makes the noise unless i turn the wheel the whole way...first i thought it was the tensioner...then i thought it was the idler pulley, then i thought it was the power steering or a/c...after discovering that it was none of these, i found out it was my damn motor mounts...read the haynes manual..it says if your motor mounts are ripped, then your engine shakes and vibrates things on the belt..this makes the clacking noise...anyway you should replace it as soon as possible because it inreases wear to everything on your belt, including the belt....if you have a top motor mount...its right above where ur timing chain would be and all that....right by the belt...it has 5 bolts that take it off (dont take it off just yet)..visually inspect the mount and if u see it torn or anything, then u know for sure thats the problem...now theres still a chance it could be the tensioner or pulley..but usually when one of these are broken it tends to make the belt squeel...like how it does sometimes when the belt gets wet...anyway check the mounts im pretty sure its the problem
#7 |
lol i also have a 93 sl2 so you probably also have the top motor mounts..by the way your lower mounts could be bad too...i'm gonna replace them...the noise also started for me after having the tensioner replaced, thats the wierd thing..and then i went around thinkin it was the tensioner or something else on the belt because of that...by the way, does your car bog out when you floor it from a stop....does it take a while to get the rpms up from a stop...is it really hard to spin the tires from a stop?...these are all signs of a busted mount...also do you do a lot of powerbraking...i believe this is the cause of busted mounts
#8 |
Hey guys, that sounds exactly IT!! i must have tore it when I reinstalled the mount, new mount tomorrow, thanks a bunch guys.
#9 |
Rattle is still there, I replaced the upper mount.
#10 |
yea, i'm replacing my lower ones too, the cost effective way!...i ordered the oem upper mount for 36 bucks from my friend...i just finished ordering the lower dogbone mount inserts (polyurethane or whatever) from xrc for 50 sumthin bucks, shipped...chances are ur lower ones are a lil messed up and if they are, it wont be long untill the upper one breaks again...thats why i bought the lower inserts...this guy free5style sayd that he replaced his mounts with the hardened sps ones and they ripped too...he said the xrc polyurthane inserts are much much better and havent ripped yet, but the twistec polyurethane motor mounts that come with a new bracket ($130 for both?) are even better...anyway im installing all 3 at the same time and if my noise isnt gone by then, i'm gonna be really really pissed...
#11 |
I'm thinking of selling the car now, this is just rediculious. I'm looking at getting an Audi A4. We'll see, i'm just bumbed that my car is PISSING ME OFF
#12 |
![]() Join Date: Jun 2002
don't let it bother you. if you really hate working on your car or replacing things, take it to your saturn dealer. Take the money you'd spend on the overexpensive A4, and put it into some work on your Satty. It'll be worth it and you'll have an equally comparable or better car than that A4.
Bookmarks |
Mom/Pop Used Car lot turning into a Saturn Lot | 2NDSOUT | S-Series General | 18 | 10-16-2008 09:41 AM |
Does anybody know what glue works on the palstic parts of my 93 saturn sl2 | MuniMan | S-Series Tech | 8 | 04-12-2005 12:51 PM |
Thanks A lot Saturn...... | saturn250hp | L-Series General | 54 | 02-03-2005 10:55 AM |
Seems like Saturn will take a lot from Opel. | salemSL2 | General Saturn Discussion | 7 | 01-11-2005 05:05 PM |
Need a Saturn Tech who works out of his house. | beachsaturn | General Saturn Discussion | 4 | 07-08-2003 03:09 PM |
