Old 08-25-2002, 12:43 AM   #1
gunny
gunny is on a distinguished road
Default Horn not working
My horn stopped working on my '99 SC2. I checked the fuse and it's fine, any other suggestions?
Add to gunny's Reputation
Rate the quality of this post and help gunny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gunny is offline
Old 08-25-2002, 12:56 AM   #2
wolfman
wolfman's Avatar
Default
Horn relay? Try swapping it out for one of the others as they are all interchangeable. To test the horn itself, disconnect the plastic connector from the horn itself. You will see 2 metal electrical connectors. Using power and ground supplied directly from the battery via a wire..touch ground to one contact and hot to the other..the horn should sound. If it does not recheck your connections at the battery and try again to confirm. If it still does not sound remove the horn and take it with you to any autoparts store..they are pretty much universal fit but there are several different versions of the connector...buy the one that matches exactly (plug and play) should run you around $15.
Add to wolfman's Reputation
wolfman is offline
Old 08-25-2002, 01:38 AM   #3
gunny
Default
Thanks, I'll try the relay, but which relay under the hood deals with the horn?
gunny is offline
Old 08-25-2002, 04:15 AM   #4
wolfman
wolfman's Avatar
Default
The underhood relays are labeled either on the fuse box itself next to each fuse/relay or on the inside of the cover.
wolfman is offline
Old 08-25-2002, 07:43 AM   #5
sattech
sattech is on a distinguished road
Default
Since '96, the horn relay is part of the horn. Best guess is a bad horn. To check it, remove (2) 10mm bolts holding the left headlight assy and remove the headlight assy. The horn is bolted to the left frame rail. Remove the (3) wire conn on the horn. One term should have constant 12v. One term should have constant ground. The third term should have a ground when the horn button is depressed. Can't remember off the top of my head which term #'s but with (3) wires it will be easy enough to figure out.
If wiring is good, horn is bad.
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 08-25-2002, 12:10 PM   #6
Mark G
Mark G is on a distinguished road
Default
I am willing to bet that your horn is just bad. The brand horn that comes on Saturns is crap. I am now on my third horn. My brothers Nissan Frontier uses the same brand horn as Saturns. He is on his 4th horn. The bad thing is that wether you go to the dealer or a auto arts store, they all carry the same brand horn, so you are kind of stuck.
Add to Mark G's Reputation
Rate the quality of this post and help Mark G reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark G is offline
Old 08-25-2002, 11:09 PM   #7
Tatusmi
Tatusmi is on a distinguished road
Tatusmi's Avatar
Default
simple solution: use the finger
- Tatusmi
Add to Tatusmi's Reputation
Rate the quality of this post and help Tatusmi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tatusmi is offline
Old 08-25-2002, 11:37 PM   #8
wolfman
wolfman's Avatar
Default
DOUGH! I gotta get into the habit of paying attention to the year of the cars in these posts!
wolfman is offline
Old 08-26-2002, 07:30 AM   #9
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Post Horn wires explained
  • "A" (colored wire) - goes to power, hot at all times, for the horn
  • "B" (black wire, middle position) - goes to horn buttons (momentary contact switches) on steering wheel
  • "C" (black wire, outer position) - ground from the horn
If you want to add an aftermarket horn, tap into wires "A" and "B" on the horn wire harness for the new horn (or for the new horn's relay coil).
David 93 SL2m is offline
Old 08-26-2002, 12:17 PM   #10
Qlara
Qlara's Avatar
Happy
- Tatusmi
LOL!
But for idiotic drivers/pedestrians, the Horn's soundwave actually wake them up faster than Image from a finger......
I think that's the reason why they didn't see you in first place.
'99 Model MAY still under warranty, try to ask the dealer and see if they honor the warranty for horn replacement.
Add to Qlara's Reputation
Qlara is offline
Old 08-28-2002, 01:52 PM   #11
XtremeGrandAm
XtremeGrandAm is on a distinguished road
Default
I know a few people whose newer saturn's horns dont work maybe they should have stuck with the relay
Add to XtremeGrandAm's Reputation
Rate the quality of this post and help XtremeGrandAm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
XtremeGrandAm is offline
1999 Saturn SL horn - new not working ysabeau L-Series Tech 4 09-07-2009 02:32 PM
Horn not working hlp plz! Salsa88 S-Series Tech 12 12-28-2007 12:38 AM
expiermented to day on 97 sc1 horn replaced with honda horn,whadda ya think! maestro S-Series Tech 1 07-27-2007 12:52 AM
Horn not working, which fuse is it? bankerbob S-Series Tech 2 08-14-2006 01:48 PM
Horn button not working Lee3333 S-Series Tech 3 06-13-2005 09:47 PM
