Old 02-14-2008, 12:44 PM   #1
SimPlyxTriPPiN
SimPlyxTriPPiN is on a distinguished road
SimPlyxTriPPiN's Avatar
1995 SC1
Default Sunroof leaking, hlp plz
So i guess this be just a 'typical' sunroof leak. but who knows.
I tried a little searching and found ALOT of people who has leaky sunroofs. So i checked it out. I realized that they usually point out the drain tubes of the sunroof. The problem is that these threads dont tell me where they drains tube go or where they are. The writers usually already checked the drains or people tell him/her to check the drains. But i haven't read anything about where they are in the car.
p.s. the car is a 97 sc2 manual
Add to SimPlyxTriPPiN's Reputation
Rate the quality of this post and help SimPlyxTriPPiN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SimPlyxTriPPiN is offline   Reply With Quote
Old 02-14-2008, 01:19 PM   #2
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Default Re: Sunroof leaking, hlp plz
Drains ;
With the moonroof open, you can find the drains about 3 to 4 inches from the front ,one on each side, it is my understanding that the other end exits the car right behind the front kick panels,with a filter assembly there.
Think it looks like a small fire hydrant, this is what i read the other day here.
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 02-14-2008, 01:27 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
a hose leads away from each corner of the sunroof assembly, and down the A and C pillars. Bottom of the front hoses is behind the trim piece and a bit of rubber by where the front occupants' feet sit, you can access it by removing the trim piece that goes under the doors and by your feet. The bottom of the rear hoses is hiding behind the side carpeting for the trunk.
Add to PurdueGuy's Reputation
Old 02-14-2008, 02:53 PM   #4
Dr B
Dr B's Avatar
1992 SL2
1993 SL2
Sorry about that ;
I thought he had a MOONROOF , disreguard my post!
Old 02-14-2008, 04:42 PM   #5
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
front,rear
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-14-2008, 04:48 PM   #6
SimPlyxTriPPiN
1995 SC1
i thought moonroofs are sunroofs?
i removed the panel near the passenger side in the front. Then i this rubber cover. Once i did that, i was a big hole, about the size of a deck of cards. There a took that goes from top to bottom. The bottom is seems to go through the floor. Is this the drain tube? If so, do i have to take the body part on the bottom of the door to get to the end of the tube?
Old 02-14-2008, 07:51 PM   #7
SimPlyxTriPPiN
1995 SC1
i think i got it. I just had to pull the tube . Now, i pour water on both front corner and water sips down and falls from the bottom of the car. I wont know for sure until my headliner dries up (rained this morning) and i give it the car a wash. Thanks for the help
Sunroof Leaking jrufener34 S-Series General 3 10-22-2009 01:28 PM
leaking sunroof wednesday S-Series General 9 05-06-2009 02:48 PM
I need diagrams of sunroof disassembly plz TwinRevver S-Series General 3 08-10-2008 11:05 PM
Horn not working hlp plz! Salsa88 S-Series Tech 12 12-28-2007 12:38 AM
sunroof leaking? mikemrq S-Series General 1 02-15-2005 04:32 PM
