Old 08-16-2018, 01:58 PM   #1
Packrat1
Packrat1 is on a distinguished road
2001 SW2
Default po037 came back
So I got a code po037 right after replacing the valvebody. Hooked up an ohmmeter to terminals C and D on the sensor. Showed 13.1 ohms. I believe the limit is 12ohms, so installed a new Bosch replacement and cleared code. Started car, went in the house for couple minutes, came back, ses light is back on. Po037 came right back. Any thoughts?
1995 Saturn SW2 5speed (retired @ 350,412 miles)
2001 Saturn SW2 (work in progress)
Add to Packrat1's Reputation
Rate the quality of this post and help Packrat1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packrat1 is offline   Reply With Quote
Old 08-16-2018, 02:07 PM   #2
Default Re: po037 came back
From the service manual;
The heated oxygen sensor 2 (HO2S-2) is located behind the catalytic converter. The sensor is used by the powertrain control module (PCM) to determine the oxygen storage capability of the catalytic converter. Due to the location of the HO2S-2, a heater element is required to provide additional heat which speeds up sensor activation time. The PCM will command the heater ON (supply ground path) after the first 45 seconds of engine run time and will not turn it OFF until the engine is turned OFF. The PCM monitors the heater current draw and will set DTC P0037 when the heater is commanded ON and the current draw into the PCM is too low.
DTC Parameters
DTC P0037 will set if HO2S-2 heater current is less than 0.17 amps with heater commanded ON when:
*The condition exists for longer than 0.5 seconds.
*The battery voltage is greater than 10.9 volts for longer than 0.5 seconds.
*The engine run time is greater than 45 seconds.
DTC P0037 diagnostic runs continuously after 45 seconds of engine run time when heater is commanded ON.
DTC P0037 is a type B DTC.
Diagnostic Aids
To locate an intermittent problem, use a scan tool to monitor HO2S HEATER - LOW VOLT or HO2S HEATER - OPEN test after engine has been running over 45 seconds. When a fault (open or short to ground) exists, the scan tool will display TEST FAIL for both tests.
The test updates every 100 ms whenever the engine is running over 45 seconds and the device is being commanded ON via the PCM.
The heater may be commanded ON before the first 45 seconds of engine run time if the calculated converter temperature is high enough.
The heater element resistance is 12-27 ohms.
Old 08-16-2018, 02:53 PM   #3
Did you try unplugging it, and plugging it back in?
No, seriously.
I researched P0037 some time back and that was the most common solution. The wiring for the secondary O2 goes over a crossframe member (somewhere slightly inboard from the driver side front tire, IIRC) and there is a connector right there. Unplug, (give a spritz of electronics cleaner if you have some handy, let dry) and reconnect.
Old 08-16-2018, 04:07 PM   #4
toggenburg
toggenburg's Avatar
Packrat,
Last night on your reverse slam thread, at 6:26pm you said
"Ok. Drove about 15 miles today. Seems to be back to normal, but check engine light persists. Replaced downstream o2 sensor and cleared the code, but came back right away. What else would trigger a po037?"
If you had noticed, I answered your question 12 minutes later by saying:
"I have no experience with that heater code, however; back in 2009 while addressing that code on a '98, OldNuc said,(P0037 Heater Circuit Low Voltage)
http://www.saturnfans.com/forums/sho...d.php?t=136349
"You can try disconnecting and reconnecting the plug. Its located on the rear cross tube of the cradle, right behind the steering rack. There is a connector lock pin in it that has to come out before it will unplug."
Old 08-16-2018, 10:34 PM   #5
Packrat1
2001 SW2
I can't believe that actually worked. Unplugged and plugged back in about 10 times for good measure, then pulled the pcm b fuse to clear the code, started up and light is out. Hope it dont come back any time soon.
Old 08-17-2018, 11:21 AM   #6
I know, right?
It's almost a joke in the computer / IT fields, and a meme in its own right
Old 08-17-2018, 10:56 PM   #7
Packrat1
2001 SW2
Dang. Code came back again this morning. Guess next attempt will involve contact cleaner.
Help, My back seat will not go back up! calvarystand Astra General 9 03-04-2013 02:16 PM
I'm back! Ha. USMCBride11306 S-Series Tech 4 04-24-2009 11:45 AM
test drove Vue RL and RAV4 back to back MJD1001 2008 Vue 4 08-13-2007 09:55 PM
im back in the ion 06ionsedan Ion General 2 06-01-2006 11:18 AM
Got my Vue back!!! dansvue Vue General 7 04-28-2004 03:44 PM
