Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 07-19-2002, 08:17 PM   #1
OvenRude
OvenRude is on a distinguished road
OvenRude's Avatar
Default Iceman intake installation questions (2)
Ok I just installed the iceman cold air intake, and have two quick questions that have poped up.
#1 - Where should the air sensor go, there is no where that I have seen to put it, and the instructions never even mensioned it.
#2 - Will this intake be affected by water if it were to rain since it is in the open?
Thanks much!!
Add to OvenRude's Reputation
Rate the quality of this post and help OvenRude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OvenRude is offline
Old 07-19-2002, 09:05 PM   #2
Sam96SL2
Sam96SL2 is on a distinguished road
Sam96SL2's Avatar
Default
1. the sensor should go right after the filter on the intake tube...i dont know about the iceman but the hotshot is predrilled
2. nope
Add to Sam96SL2's Reputation
Rate the quality of this post and help Sam96SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sam96SL2 is offline
Old 07-19-2002, 09:38 PM   #3
Tatusmi
Tatusmi is on a distinguished road
Tatusmi's Avatar
Default
I don't know about rain... it should be fine. but I've been told that alot of water isn't good... it'll get sucked into your engine if there is alot of it... if you have it down too low (to the ground) or if it's nested right in a vent it might become a problem.
- Tatusmi
Add to Tatusmi's Reputation
Rate the quality of this post and help Tatusmi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tatusmi is offline
Old 07-20-2002, 01:58 AM   #4
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default
Well, if it's literally ON THE GROUND, and you start going driving through DEEP puddles, then the likelyhood of water getting sucked up is pretty good. But for a normal rain, and driving..you should be ok. It'd be pretty hard for water to climb ALL the way up that intake and into the motor.
Add to TIMSPEED's Reputation
Rate the quality of this post and help TIMSPEED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TIMSPEED is offline
Old 07-20-2002, 07:20 AM   #5
OvenRude
OvenRude's Avatar
Default
Do you think that it would be okay to have the air temp sensor just near the filter? I think that should be fine, and not require me to drill a hole, I just don't want it to screw with the cars comp. chip and tell it that the air is messed up.
OvenRude is offline
Old 07-20-2002, 11:36 AM   #6
OvenRude
OvenRude's Avatar
Default
Ok, I just drove, and it smelled like an engine... yeah
Is the air temp sensor important enough to keep things cool for me to drill a hole in the side and stick it in there?
OvenRude is offline
Old 07-20-2002, 11:41 AM   #7
wingnut
wingnut is on a distinguished road
Default temp sensor
The more accurately the temp sensor is reading your air the better the computer can decide the right amount of fuel to put in. Drilling a hole is probably the most accurate but I have heard of several people putting it on or near the filter without any problems. As long as it is measuring the air going into the engine and not the air under the hood you should be alright.
Add to wingnut's Reputation
Rate the quality of this post and help wingnut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wingnut is offline
Old 07-20-2002, 12:33 PM   #8
Yobos4vr
Yobos4vr is on a distinguished road
Default
i thought the iceman was predrilled for the IAT sensor? also wasn't it drilled for a nitrous jet??
Add to Yobos4vr's Reputation
Rate the quality of this post and help Yobos4vr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Yobos4vr is offline
Old 07-20-2002, 10:51 PM   #9
OvenRude
OvenRude's Avatar
Default
There were no pre-drilled holes in the intake, I wish there was though. I know its nitrus compatible, and it did have the hosing connecter that goes into the engine.
I think I will just drill a hole in it and put some high temp sealant around it, since today I noticed that my temp guage would move up to middle within the first minute before settling at just above 1/4.
OvenRude is offline
Old 07-22-2002, 08:51 AM   #10
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Iceman intake installation questions (2)
Thanks much!!
1. you need to drill a hole into it and screw it on, somewhere near the k&n filter on the end.
2. not unless you drive in water as deep as your headlights. don't go roaring though deep puddles.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 07-22-2002, 08:53 AM   #11
eRic 02sc2
eRic 02sc2's Avatar
Default
no it's not. there is a flat spot where you can drill into it and insert a nossle.
eRic 02sc2
FS: Iceman intake fastwheels Classifieds 4 05-02-2003 04:44 PM
iceman intake swoker183 Mods and Performance 4 08-09-2002 09:26 PM
Iceman Intake for sale Madson26 Classifieds 3 08-09-2002 05:53 PM
Iceman intake bracket installation David 93 SL2m S-Series Mods 9 07-02-2002 06:41 AM
Iceman intake nitrofumesrule! Classifieds 7 06-24-2002 01:02 AM
