Old 08-16-2018, 03:38 PM   #1
Barnett
Barnett is on a distinguished road
Default HAI: How hot is to hot?
'96 SC2. So I got a piece of 3" vent pipe and a 90 elbow run out of an airfilter box from a junk yard SW2 and put a spare IATS in the airstream, approximately in the same position the actual IATS is in the airstream, from the pipe inside the filter box wired to a digital multimeter in the cabin for cheap real time monitoring as I drive. It got down to 290ish ohlms which would put the air temp at around 190f ish according to Oldnuc's temp chart I found in here. I didn't feel any noticable loss of power on my drive to work this morning.
So as the title says, how hot is to hot?
Add to Barnett's Reputation
Rate the quality of this post and help Barnett reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Barnett is offline   Reply With Quote
Old 08-16-2018, 04:31 PM   #2
Barnett
Default Re: HAI: How hot is to hot?
Ambient temperature this morning was 70s.
More info from my commute home. Ambient temperature is 85, resistance dropped to 180 ohlms when at traffic lights, with one instance of dropping to 90 olhms (260 ) driving slowly through the mall parking lot to stop by harbor freight. The car seemed to act fine, though, but that is way too hot for my comfort.
Going 60 on the highway the resistance hovered around 300 olhms (180).
Old 08-16-2018, 06:35 PM   #3
Barnett
The first pic is how my HAI was setup this morning. Minus the slits, I started making adjustments before I took a before pic. I had the vent pipe butted up to the manifold. That yielded way to high intake temps, though I would have expected melted plastic in the air filter box there wasn't any.
After cutting the slits in the vent pipe I realized that I could just angle the pipe back like in the second pic. So I can make adjustments without mangling the vent pipe elbow
We'll see how it goes in my commute tomorrow.
Old 08-16-2018, 08:42 PM   #4
How hot is too hot for a hot air intake? The simple answer: when plastic melts. Now your question will be what type of plastic is used in the intake air tubing and its melting point? Other plastics melting points? Plastic used in sensors? Perhaps you should consider temperature probes dedicated to a meter for on board monitoring instead of continually converting resistance values to temperatures? I use one with dual temperature probes to check icebox, oven, hot water heating systems, etc..
What purpose is this hot air intake for?
Old 08-17-2018, 10:34 AM   #5
To a certain point the hotter the better; once it gets too hot it'll either ping from pre-ignition or add fuel reducing MPG.
150f appears to be the sweet spot; lower and the gains aren't there, higher and the engine makes too little power to out run a bicycle uphill.
Old 08-17-2018, 11:13 AM   #6
Barnett
Yup, definitely had reduced MPG, especially after I turned the A/C on to run the fan. The engine temp gauge got down to the 1/4 mark so it was running rich to try and warm up.
I'll aim for 150, I will have to come up with someway to regulate the intake air temp.
Thanks
Old 08-17-2018, 11:37 AM   #7
Nice set up. How much mpg are you getting from this, or too early to tell?
Always had in mind to set up something similar, but in 9 years never made the time. Had something like this in mind for adjustment
Old 08-17-2018, 11:56 AM   #8
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
I got a 2-3 mpg gain just from adding in a "short ram" intake on my SW2. It's just sucking warm air from the engine compartment. I expect getting closer to the exhaust manifold could likely get you a 3-4mpg boost.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 08-17-2018, 12:05 PM   #9
About 14 years ago now Cheapybob got his '97 SC1 to over 50mpg with a WAI and some aero mods.
Various threads:
http://www.saturnfans.com/forums/showthread.php?t=71674
http://www.saturnfans.com/forums/showthread.php?t=77237
http://www.saturnfans.com/forums/showthread.php?t=74808
http://www.saturnfans.com/forums/sho...d.php?t=175694
Old 08-17-2018, 01:29 PM   #10
I came to the same conclusion about this post, relative to cheapybob............ He did it without concern about measuring resistance and converting values to temperatures going into the intake air system. I believe he looked past this by keeping his eyes on the gas gauge to achieve mpg numbers and maintaining the same route to control as many variables as necessary to prevent skewed results. In the end, he decided on switchable values to allow for cold engine startups without stumbling issues arising from leaned out fuel mixtures when cold engine startup tends to run better with rich mixtures then switching to lean conditions as soon as he was underway to allow engine loading to hasten warm up temps. While not scientific, he still achieved remarkable fuel economy by painstakingly documenting every step to have a record if something went wrong to review notes and sharing his experiments here.
Old 08-18-2018, 06:32 PM   #11
laser3kw
laser3kw is on a distinguished road
2000 SC1
I run a similar setup on my 2000 SC1. I monitor my IAT with a Scangage to see what the ECU is reporting. I have had temps as high as 200 and most of the time, in years past, it runs in the 160 ~190.
Little sluggish? Meh, I am not doing it to run ET's.
This year, I uncoupled it a little and run around 140 ~165. Does seem a little peppier.
current mpg is 42 - just measure today, miles driven / gallons at the pump.
Weekly miles 240 or so, some in town and some highway.
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
