Old 06-23-2008, 01:47 PM   #1
mperzichilli
mperzichilli is on a distinguished road
Default Air Conditioning
I'm a DIY noob, but fast adding skills to repitoire as I patch up my 96 SL2. Replaced my radiator this last weekend due to leaking from cracks in the plastic. Though I should have been able to move the condenser and radiator together to some extent, but after I took out the lower attachement bolts, the condenser just fell out. The plastic retaining clips on the top must have not provided a good fricton fit.
Anyway, as a result of this the condenser hoses underwent a few contortions while I put everything back together. Now when I run the AC it is exceptionally noisy -- scarily so -- and the noise sounds like mechanical friction or wear. It is still blowing cool (not cold, it wasn't ever really that cold). Did I cause it to leak? What can/should I look at to accurately diagnose the problem?
Thanks in advance.
-MP
Add to mperzichilli's Reputation
Rate the quality of this post and help mperzichilli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mperzichilli is offline   Reply With Quote
Old 06-23-2008, 01:59 PM   #2
scottyboost
scottyboost is on a distinguished road
Default Re: Air Conditioning
You need to be a little more specific about what the noise is.
There are basically 3 "moving parts" in the AC system:
- compressor/clutch
- cabin fan
- radiator fan
If there is excessive noise, then it most likely will be one of these parts.
98 SL2 207k, still getting 28mpg city
86 Buick T-type 228k, extreme tire shredder
Add to scottyboost's Reputation
Rate the quality of this post and help scottyboost reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scottyboost is offline   Reply With Quote
Old 06-23-2008, 09:27 PM   #3
mperzichilli
the noise is at the compressor. Only makes the sound when ac is engaged (turned on). Fan is operating fine.
Old 06-23-2008, 10:02 PM   #4
If you didn't bend/flex aluminum tubing that's too malleable (leading to cracking and eventual refrigerant leakage along with oil as a telltale sign) the noise may be the compressor protesting the lack of refrigerant. Just don't run the a/c anymore until you have gone over the entire system visually looking for any signs of a leak; http://www.saturnfans.com/forums/showthread.php?t=80107. The time spent finding the source of the leak will pay off if/when its decided how to repair the system and if you can do the lions share of the repairs to cuts costs down considerably, including having the system finished by the local a/c shop if you don't have the equipment.
air conditioning went out puckalicious S-Series General 13 07-20-2010 04:17 PM
air conditioning kingvandal S-Series General 2 05-17-2008 02:35 PM
Air Conditioning DragosteaDinTei S-Series General 2 07-12-2006 02:15 PM
Air conditioning Yev S-Series General 14 08-09-2004 11:36 PM
Air Conditioning silverplum Ion General 18 07-31-2000 10:24 PM
