Old 05-22-2018, 09:19 PM   #1
04nastysedan
04nastysedan is on a distinguished road
Default 04 ion no power to wiper motor?
Good fuse, power to fuse box, if it is the 15 amp in the box. Tried two new relays. Any other ideas?
Add to 04nastysedan's Reputation
Rate the quality of this post and help 04nastysedan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
04nastysedan is offline   Reply With Quote
Old 05-22-2018, 11:12 PM   #2
Default Re: 04 ion no power to wiper motor?
Here's the wiring diagram for your wipers. There are two fuses, a 10 amp wiper fuse in the body control module and a 25 amp fuse in the engine fuse block. Google for procedures to remove the bcm in between the center accessory and floor console if necessary unless the fuse is visible. The bcm will have two large multi-pin connectors on one side.
Old 05-23-2018, 10:32 PM   #3
04nastysedan
Also I found if I jump power to high or low I can make it work from using the yellow wire off the switch. I found a grey wire under the column which was broke off. Unsure of what that has to do with anything... But still no power even if I jump it yellow wire where there's power by the switch, to the yellow by the motor
Old 07-03-2018, 05:00 AM   #4
Richardrobert
Richardrobert is on a distinguished road
Wipers may be powered through a ramification of approach, despite the fact that most in use these days are powered by way of an electric motor via a chain of mechanical additives, commonly two 4-bar linkages in series or parallel. motors with air operated brakes every so often use pneumatic wipers, powered by means of tapping a small amount of pressurized air from the brake machine to a small air operated motor hooked up on or just above the windscreen
Add to Richardrobert's Reputation
Rate the quality of this post and help Richardrobert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Richardrobert is offline   Reply With Quote
wiper motor compatibility? 2002 sl2 motor in 97 sl2? vikasevan S-Series Tech 2 04-04-2015 02:06 AM
wiper motor trevorwt1995 S-Series Tech 0 04-06-2013 02:49 PM
Windsheild wiper motor or wiper arm switch? shinotheweevil S-Series General 3 11-06-2010 01:22 AM
No Power to Wiper Motor barney fife 5 S-Series Tech 12 12-21-2007 08:47 AM
Wiper Motor Phantom S-Series General 2 02-25-2005 01:09 AM
