Old 08-07-2018, 02:31 PM   #161
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default Re: and so it begins....
You know what, I think I used that guide to track down my rattle! Full circle!
Our 99 has the exact interior, and I have only seen 1 other with it throughout craigslist and facebook marketplace.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 10-14-2018, 08:53 AM   #162
trottida
trottida's Avatar
Doing an oil change yesterday and looking at my suspension components. I replaced the control arms earlier in the summer and a couple months later I noticed my left and right tire was getting scrubbed on the outer edge. I figured the control arm changed the alignment somehow so I got an alignment. I replaced the tie rod ends and put in new struts before doing the alignment. The right side however I think is still getting scrubbed. Take a look at the control arm at the engine cradle. Does it look like it is sliding to the right? Has anyone seen this before? Is this possible?
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-14-2018, 09:24 AM   #163
It does look to be a bit displaced. Measure the amount of sleeve on each side and compare to the other side measurements. It does not take much displacement to radically change the steering geometry.
Old 10-14-2018, 10:51 AM   #164
trottida
trottida's Avatar
Is that piece supposed to be fixed and if so how? I'm thinking yes.
Looking at the notch in the LCA mount I think it is currently centered but it looks like it has been moving to the left intermittently, based on the marks in and about 3/8" or so.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-14-2018, 12:58 PM   #165
Yes, supposed to be a press fit, tight.
Old 10-14-2018, 07:06 PM   #166
trottida
trottida's Avatar
I take it that it is scrap metal now.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-14-2018, 07:50 PM   #167
Yes, I would replace it with a new one from a different Chinese factory. The brand name on the box means nothing as to quality either.
This guy has brick and mortar stores in Canada and quality parts: https://www.ebay.com/usr/maximum_sus...p2047675.l2559
You can probably contact him through eBay and locat what you need.
Old 10-15-2018, 08:08 AM   #168
trottida
trottida's Avatar
I bought the one from my photo from Rockauto and it is the Mevotech brand from the Daily Driver section.
https://www.rockauto.com/en/moreinfo...357264&jsn=336
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-15-2018, 09:02 AM   #169
Quality is all over the place and the guy I linked above is one of those sellers that is picky about the quality of the parts he sells.
Old 10-15-2018, 09:22 AM   #170
trottida
trottida's Avatar
I reached out to him. He doesn't show any Saturn parts within his eBay store or website. We'll see what comes of it.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-15-2018, 11:46 AM   #171
trottida
trottida's Avatar
So another development, rather than deal with an RMA to RockAuto I reached out to Mevotech technical support since they are in Southern Ontario (3 1/2 hours south of here). I sent them an email with the photos describing the issue at 11:16 AM and they called me at 11:23. That's pretty impressive.
Anyways, the tech said that they press those in from right to left and what I'm seeing is the marking from the press is process. That area has presented a bit of rust since I installed them in May making it more pronounced. He said the other side should look similar.
He asked me to go ahead and get an alignment and to send him the before and after specs so they can see what is going on. The new tie rod ends are Mevotech too.
I have the car in at an alignment specialist shop today for other reasons and they are going to double check the suspension and give me an opinion. If they think it is good I'll have them do the alignment later this week.
The previous alignment was done at Canadian Tire which is not my first choice but they accommodate weekends. I was able to do the work and get the alignment on a Saturday. If I recall I had a trip planned on the Sunday.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-15-2018, 01:12 PM   #172
He only lists fast movers on eBay. Should have the Saturn stuff at the store though. Nice to see Mevotech has a functional customer support, that is a good sign. Yes that sleeve is pressed in there and theoretically should not move.
Check that the cradle is not shifting around. Look at the alignment holes for signs of any displacement.
Old 10-23-2018, 11:13 AM   #173
trottida
trottida's Avatar
Had a 4 wheel alignment done and all suspension parts are good. Specs were way out and I still don't know conclusively why. I'll be keeping an eye on it. I've attached a photo of the before and after alignment specs.
I went back Canadian Tire and they refunded me for the cost of the July alignment and offered to help me out in the spring when I'm looking to replace the 2 front tires. The manager did say the alignment technician wasn't very seasoned however he couldn't really explain why the front was so off alignment after 4200 km . The rear, they didn't really do anything with - at the time said it was not adjustable which I questioned them on (Monroe struts do have elongated holes) but they assured me camber wouldn't make a significant difference. I left with an uneasy feeling but I had heard that before. The specialty alignment shop took the time to get the rear aligned.
Never heard back from the eBay seller Maximum Suspension when I emailed them directly. Oh well.
On another note. I'm having an issue with my rear defroster. It seems when it gets cold the switch does not activate. I press the button and don't hear the definitive "click" and the light does not illuminate. In warmer weather it works fine although who needs rear defrost when it's warm! Any ideas?
I also noted yesterday when changing to my winter wheels and lubing up my caliper pins that the left front brake caliper is is installed upside down. I guess this means at some time during the previous ownership that someone installed the wrong caliper mount. The right side is correct so it's not a case of reversing the 2. Is there any reason to be concerned? I know the bleeder valve is not at the lowest point but other than that should I bother correcting it?
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-26-2018, 12:35 PM   #174
trottida
trottida's Avatar
Anybody want to comment on these 2 open issues from my earlier post?
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-26-2018, 01:11 PM   #175
I'd pull the surround off and disconnect the connectors, then spritz everything with electronics cleaner. Something may be sticking, not pressing far enough, etc., when cold weather shrinks the plastics.
We rarely drink cans in the car, but last time I opened a can of Coke in the minivan, drops sprayed several feet. That stuff can get everywhere if you aren't careful
Can't comment on the brakes, outside of my knowledge - I just know the basics of replacing
Old 10-26-2018, 02:19 PM   #176
As long as the caliper is bled ok should be fine. But how do you bleed it in that configuration?
Add to Waiex191's Reputation
Old 10-26-2018, 02:46 PM   #177
trottida
trottida's Avatar
I imagine they took it off the mount and let it hang. I wasn't the one to do the work on the brake lines.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-31-2018, 08:28 AM   #178
trottida
trottida's Avatar
I'm going to post these photos here for future reference. I seem to always be looking for them for reference when replying to related posts.
This is from my 99 SL2 MT running a 2 year old Stant 14279 thermostat. This seems to be the normal gauge reading for a 99 model year based on owner consensuses. It seems low compared to my 01 SL1 but it is what it is.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-31-2018, 08:59 AM   #179
The gen-3 has a different gauge calibration and there is no direct comparison.
Old 10-31-2018, 09:08 AM   #180
trottida
trottida's Avatar
Yup..
Prior to owning a GEN2 it had the understanding from this forum that GEN2 and GEN3 were one and the same. It was never really brought forward that GEN1, GEN2 and GEN3 all had different calibrations. I try to make that known now when replying to related posts and pictures are worth a thousand words. A GEN3 displaying a similar reading to a GEN2 is likely having some issues.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Saturn in Batman Begins sallydriver S-Series General 9 12-14-2013 01:51 AM
So it begins: Rebuilding a 1995 SC2 RalliArt16 S-Series Tech 441 05-08-2013 09:55 AM
GM's Rebirth Begins Now eelfliw General Saturn Discussion 0 05-31-2009 10:07 AM
Here's Where The Fun Begins Racer93 S-Series Tech 5 03-15-2008 09:35 AM
the door makeover begins! BlueIonDriver Ion General 31 05-06-2004 11:20 AM
