#1 | ||||
Is it possible to lower the strut enough to repair or replace the mount without actually disconnecting it from the knuckle (and needing a new alignment)?
I have KYB struts and mounts, new as of last summer, and the passenger side mount has started squealing quite significantly when turning at low speeds (like most aftermarket Saturn parts I've purchased recently, it's defective). I can get the mount replaced under warranty, I believe, although that would probably be a pain because it's from tirerack (they may want me to pay for shipping to send the old one back, before they send me a new one, which would be highly inconvenient). I believe I saw a post a few months ago where someone was successful at disassembling and re-greasing a relatively new mount that was squeaking--any thoughts on that? How do I take it apart? What type of grease is best? Can I use regular automotive chassis/suspension grease (I have Mobil1 synthetic)? Thanks! ... High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
#2 | ||||
![]() Join Date: Jun 2011
You could take the entire knuckle off with with the strut still attached, although it would be a bit inconvenient and you would need a new axle nut.
#3 | ||||
Some just separate, don't know how KYB built theres. If you scribe the knuckle/strut mounting point you can reassemble without being out of alignment. Are you sure it is not one of the mount bolts rubbing on the cushion rib?
#4 | ||||||
There's not enough room to slide the mount out, when it is separated from the strut (with the strut still in place)? Quote:
I'm not sure what you mean about the bolts, could you explain that a bit more...? It didn't make any noise for the first 10 months... just started the other day. ... High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1 Last edited by PlasticCarsRock; 06-23-2012 at 09:34 PM..
| Thread Tools | |
| Display Modes | |
| upper strut mount repair | whiteshadow | Aura General | 0 | 05-18-2012 11:44 PM |
| bad upper strut mount diagnosis & repair cost | saturnsctwo | S-Series Tech | 23 | 09-07-2011 09:55 AM |
| How-to replace just the upper strut mount | BobbyBeans | S-Series Tech | 7 | 06-04-2009 10:32 PM |
| Dealer replaced strut, strut mount, and strut bearing | tomcatt1 | Vue General | 17 | 10-03-2007 03:53 PM |
| Replace front strut mounts - Alignment needed? | Red97sc2 | Miscellaneous Tech | 1 | 09-19-2004 01:31 AM |
