Old 12-08-2009, 09:24 AM   #1
jerryt
jerryt is on a distinguished road
Question 2004 Vue heater fan not working
I have a 2004 Vue. The heater fan is not working. It comes and goes. The car will run and the fan will suddenly stop. Then after a while the fan will run normally and blow hot air.
What should I look for in diagnosing this problem?
Thanks,
Jerry
Add to jerryt's Reputation
Rate the quality of this post and help jerryt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jerryt is offline   Reply With Quote
Old 12-08-2009, 11:11 AM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: 2004 Vue heater fan not working
Thanks,
Jerry
Jerry ... does the fan operate OK when position 4 (high) selected?
If yes, problem could be in resistor network.
If no, could be corroded wiring between blower and under-hood fuse.
You can find more info by searching on "vue heater blower" and see post # 3 in attached thread for link to a diagram.
http://www.saturnfans.com/forums/sho...+heater+blower
Old 12-09-2009, 10:52 PM   #3
IMkenNY
IMkenNY is on a distinguished road
Iif it only fails on the high speed fan setting the common problem is the actual fan speed switch.
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Heater fan not working tjohnny42 Vue General 4 12-29-2009 06:41 PM
2004 saturn vue Air condioning sometimes working sometimes not. Help. electricbluevue Vue Tech 10 08-08-2009 01:54 PM
2003 Saturn Ion Heater/AC fan not working BluePele Ion Tech 6 03-25-2008 09:51 AM
06 Vue: constant air from heater when fan off? powdereatin Vue General 18 09-26-2005 07:20 AM
