Old 08-30-2007, 10:37 PM   #1
smalltownjava
smalltownjava is on a distinguished road
Default Please help with cleaning Sunroof Drains
You guys are great and I'm sure some one can answer this real quick. Where in the forums is a howto on clearing the drains to the Sunroof?
I have the A-pillar cover poped off, the Kick plate removed, the base running board removed and the wheel well guard removed.
I can see the top right hose drain clearly under the headliner and it is firmly attached.
However, when puring some water in the trough around the sunroof, it bairly bubles down.
I can see the water exiting at the bottom just behind the front right door. Its trickling directly trough the metal seams where the jack is supposed to go.
I cannot find the end of the drain hose.
Can someone post a picture or explain what I'm missing?
Thanks!
-Dave in Birmingham, AL
Add to smalltownjava's Reputation
Rate the quality of this post and help smalltownjava reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smalltownjava is offline   Reply With Quote
Old 08-30-2007, 11:15 PM   #2
smalltownjava
Default Re: Please help with cleaning Sunroof Drains
Stupid, links showing related threads contained the answer. Sorry for the waste of space.
Old 08-31-2007, 09:56 AM   #3
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Thanks!
Here are the front and rear drain locations.
http://i202.photobucket.com/albums/a...oofdrain1a.jpg
http://i202.photobucket.com/albums/a...oofdrain1b.jpg
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-10-2007, 08:55 AM   #4
Hink3000
Hink3000 is on a distinguished road
I'm having the same problem. Leaking sunroof. Unfortunately I'm such a newbie I can't find the related links you mentioned. Could you post the link or explain how I find it?
Add to Hink3000's Reputation
Rate the quality of this post and help Hink3000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hink3000 is offline   Reply With Quote
Old 09-10-2007, 09:23 AM   #5
richpin06
richpin06's Avatar
The front is located here and the rear is located here
Old 09-15-2007, 10:14 AM   #6
Is the front one high enough to make water drip down from the glove box area? I'm having trouble picturing the exact placement of it, but I've never had the kick panel off.
I'm about ready to just cut a section out of one of my '93s and JB weld the sucker in place of the sunroof (sunroof to no sunroof conversion...I've got enough "no sunroof" headliners...). I hate the stupid thing.
Old 09-15-2007, 03:13 PM   #7
Hink3000
Thumbs Down Re: Please help with cleaning Sunroof Drains
I'm the same way. I hate my stupid sunroof The motor's broke three times and now it leaks. I hardly ever used it and the motor burned up. Had nothing but trouble with it since I got the car. $600 for Saturn to replace it is not worth it IMO.
Old 09-16-2007, 01:24 AM   #8
SatSL2fan
SatSL2fan is on a distinguished road
SatSL2fan's Avatar
New to me.. is there a way to test the drains without pulling the panels or do you have to get in there for a visual? Does minor leakage point to a blockage?
1996 SL2 150K new tires
Add to SatSL2fan's Reputation
Rate the quality of this post and help SatSL2fan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SatSL2fan is offline   Reply With Quote
Old 09-16-2007, 10:18 AM   #9
Nevermind, I found it. Not hard, just pull/pry the kick panel (it's built into the door sill thing on my SC1) out, then pull the carpet back, then pull the rubber "flap" up.
The drain felt like it was stuck on the bottom, but very loose going up towards the roof. Is that normal? I didn't dare pull on it too hard...
Old 09-16-2007, 10:28 AM   #10
amazinghl
Get some compress air and blow the stuff out of the drain hoses.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 09-16-2007, 01:35 PM   #11
geartooth94
geartooth94's Avatar
in that front picture, why is some of the frame metal cut and bent downward? aren't you afraid of that metal rusting now?
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 09-16-2007, 02:32 PM   #12
richpin06
richpin06's Avatar
With the front of the car looking like this i think my cutting of that metal is the least of it's problems......
Old 09-16-2007, 11:17 PM   #13
geartooth94
maybe get a pic of the front a bit zoomed out so it's clearer where the tube ends. the back tube pic is perfectly clear.
Old 09-17-2007, 09:45 AM   #14
richpin06
richpin06's Avatar
Zoomed out pic.
Old 09-17-2007, 10:14 PM   #15
geartooth94
very awesome. looks like the outer fender does not need to come off then. couldn't tell if it was accessed from outside or inside.
B/T/W Charlie please sticky this thread and/or move it to the how-to. It's the first time I've ever seen clearly how to clean the sunroof drains without confusing everyone that reads it.
Old 09-17-2007, 10:30 PM   #16
TwinRevver
TwinRevver is on a distinguished road
Hey richpin, is that a leather interior?? Im looking for some leathers...
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 09-18-2007, 09:06 AM   #17
richpin06
richpin06's Avatar
It looks like those seats were leather.I say were because that car is gone from the yard now.
How do you clean out the sunroof and other drains? YourMainParadox Vue Tech 1 03-31-2009 02:16 PM
Sunroof drains? iceman_15200 S-Series General 3 12-22-2005 06:44 AM
sunroof drains john_flick S-Series Tech 0 03-24-2005 11:01 AM
Sunroof drains spider 1604 S-Series General 10 08-02-2004 02:58 AM
urgent, drains from sunroof. DOHCdude S-Series Tech 4 01-03-2003 09:27 PM
