Old 12-11-2014, 01:38 PM   #3981
Bob243
Bob243 is on a distinguished road
Bob243's Avatar
1991 SL1
Default Re: What did you do to your S-Series today...
Brushed the slush and snow off the cover this am
Add to Bob243's Reputation
Rate the quality of this post and help Bob243 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bob243 is offline   Reply With Quote
Old 12-11-2014, 11:16 PM   #3982
Lucario
Lucario is on a distinguished road
Lucario's Avatar
2002 SC1
Checked the oil, installed her new floormats that came today, gave her a fresh coat of armorall, and got a small zipper bag too keep loose important items like her paperwork and spare bulbs together in the glove box
02 SC1 "Hikaru" 83K
Add to Lucario's Reputation
Rate the quality of this post and help Lucario reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lucario is offline   Reply With Quote
Old 12-12-2014, 01:27 PM   #3983
SRGW
SRGW is on a distinguished road
1997 SL1
Post Re: What did you do to your S-Series today...
Ran a 10amp fuse and holder with new 14 gague wire to the cigarette lighter from the UHJB on the 95. Will wait till it gets a little wamer to do the 97.
No more possible problems with F5.
1995 SL1 214,663 Well Oiled!!
1997 SL1 44,250 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
SRGW is online now   Reply With Quote
Old 12-13-2014, 12:31 PM   #3984
el diablo viejo
el diablo viejo will become famous soon enough
el diablo viejo's Avatar
1994 SW1
2000 SW2
Is there a "How To" or richpin video for this ?
Just finished doing a rear wheel hub/bearing assy and brake cylinder on my 97 SL2. 17 years of NH rust
1994 sw1 5 spd 205k, 97 sl2 a/t 91k, 2000 sw2 a/t 152k,
1989 GMC 3500 454 129 K, 87 Bronco 101k, 1969 442 455 rat rod
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
el diablo viejo is offline   Reply With Quote
Old 12-13-2014, 01:21 PM   #3985
SRGW
1997 SL1
0 Prefab: solder a ring terminal to a wire fuse holder. Solder and heat shrink the other end to a 14 gauge wire.
1 Remove cover to under hood fuse panel.
2 Look to the far right and you will see a red wire from the + battery terminal.
3 Remove fuse from fuse holder.
4.Loosen the bolt and hookup the ring terminal, tighten bolt.
5 Run wire next to main harness through grommet into car.
6 Remove fuse from passenger fuse panel for cigarette lighter.( 1995 was door locks fuse)
7 Remove cover from drivers side fuse panel area and look behind lighter for orange wire. (1995 color may vary)
8 Cut orange wire solder and heat shrink 14 gauge to lighter side of orange wire, tape up other end.
9 Install fuse near under hood fuse panel and wire tie installation.
CHECK YOUR OIL!!
Old 12-13-2014, 06:21 PM   #3986
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
Changed the worn Chinese Pepboy's belt tensioner with a Canadian made Gates one. Looks close like the OEM design, even has a 14mm nut
Also, SRGW, the "orange" wire is the power input correct? So the new wire being spliced is just a direct link avoiding all of the plastic connectors that risked melting. The Door circuit is still functional after right?
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 170,000+ miles and purring smooth.
My Mug is filled with the lost souls of crushed imports. . .
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 12-13-2014, 06:55 PM   #3987
Pitcher
Pitcher will become famous soon enoughPitcher will become famous soon enough
Pitcher's Avatar
2000 SL2
Swap-a-roo day..........
- Creampuff had a 9 year old AC Delco in it & was starting to turn over slow in the cold. The $400 donor '99 SC2 had a 3 year old NAPA Legend, so I swapped them!
- I put 2 new Thermisters (ECTS & IAC) in the donor SC2 while diagnosing. BUT since the problem was all forward cam rollers were off, I pulled them & will keep them as spares. Put the ECTS & IAC back in the donor car.
- I put in a new Fuel Regulator/Filter in the donor SC2 while diagnosing, so it's pulled out to save for later & the old Fuel Regulator/Filter is back in.
More swapping, coming up...
'00 SL2. "Creampuff" 89 YO lady car. 20 oil changes 1st 33k miles. Now 84k.
'98 SC2 "Red Hot" 5-Speed. Pennzoil + Lubegard. $1600
'99 SC2 $400
'01 SL2 10th Anniversary Edition!
Add to Pitcher's Reputation
Old 12-14-2014, 01:08 AM   #3988
el diablo viejo
1994 SW1
2000 SW2
The best fuse box connection was my first question ( answered in SRGW's original post ), but my second question was the best place to attach the new 14g wire. I thought that direct connection to the cigarette lighter base socket would be best. Was not sure what was involved to remove the base from the dash and connect the new wire directly to the socket, which eliminates the OEM 16g ? wire completely.
Old 12-14-2014, 10:06 AM   #3989
SRGW
1997 SL1
Orange wire is 12 volt input feed to cigarette lighter, after taping up cut side (no shorts) reinstall fuse for door circuit.
CHECK YOUR OIL!!
Old 12-14-2014, 11:29 AM   #3990
Pitcher
Pitcher's Avatar
2000 SL2
Forgot one, lol...
Swapped Dipsticks as the Red Hot had dark burn marks on it and the one out of the donor SC2 had none.
Not too happy with the burn marks on the dipstick... Must've ran hot and/or low on oil too much, eh?
'99 SC2 $400
Old 12-14-2014, 07:23 PM   #3991
SLfun
SLfun is on a distinguished road
1998 SL1
Swapped out the broken top motor mount for a new OEM one. WOW! It's like I have a new car! Night and day difference! Sooooo smooth now! Nothing inside the car vibrates anymore...it's so weird...
Oh and I also replaced the spark plugs with some new Denso's. SAturn rewarded me by turning on it's Service Engine Light
Oh well, I'll check that tomorrow. It usually does that when remove the ignition wires for some reason...
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-14-2014, 07:58 PM   #3992
TvSteve
TvSteve is on a distinguished road
TvSteve's Avatar
1999 SW2
Replaced rotted rear brake lines. Turned out to be a mess. Both rear wheel cylinders were rotted, nothing left of the mounting bolts and bleeders. All the line mountings were shot, had to zip tie the new lines to what was left of the old. Front bleeders were rotted shut. Used a tool "brake free" to get these open.
Luckily the line burst in my driveway because the pedal went to the floor. This was on my 97 SW2 with 99000 miles on the clock, my winter car. Put the 99 SW2 to sleep for the winter.
Add to TvSteve's Reputation
Rate the quality of this post and help TvSteve reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TvSteve is offline   Reply With Quote
Old 12-14-2014, 08:15 PM   #3993
scw2
scw2 has a spectacular aura aboutscw2 has a spectacular aura about
1999 SC2
Put snow tires on my moms 96 sl2 and a new down stream o2 sensor
Add to scw2's Reputation
Rate the quality of this post and help scw2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scw2 is offline   Reply With Quote
Old 12-15-2014, 12:42 PM   #3994
Killakittie
Killakittie is on a distinguished road
Changed out the old transaxle fluid and wiped down the engine bay. She just turned over 176k miles this past weekend.
02 Sl1 5-speed 176k miles run's great!
98 Sl1 5-speed sold at 145k miles back in 07
Add to Killakittie's Reputation
Rate the quality of this post and help Killakittie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Killakittie is offline   Reply With Quote
Old 12-15-2014, 02:20 PM   #3995
dummo
dummo will become famous soon enough
dummo's Avatar
^^^^ I like that picture - Remember to submit it for the 2016 SCCNA Calendar
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 12-15-2014, 09:24 PM   #3996
Nekomimi
Nekomimi's Avatar
1996 SL1
Do you like Mud-Flaps? I heard you liked Mud-Flaps..
I had to colour match these, I think they Look pretty snazzy. Hopefully they'll protect the bottom of the bumper as well as keep the water splash down on the highway. Grabbed a pair without the red reflector for the front well's too, probably put those on at a later date.
I also swapped in SL2 front seats, they are quite nice, I can't wait for the 4hr drive to Dallas coming up
Old 12-16-2014, 10:42 PM   #3997
NWSaturn247
NWSaturn247 is on a distinguished road
NWSaturn247's Avatar
1993 SL2
Drove to Kmart and purchased three PSL20195 filters for $3.99 each.
1993 SL2 AT - 116k mi
running PP 5w-20/Valvoline NGMLHM 10w-40 + Fram PH3614
:-) Adding TC-W3/MMO to the gas with positive results (-:
Choose the red pill
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 03:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 07:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 01:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 07:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 08:03 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
