Old 08-15-2012, 07:21 PM   #1
Joshtheclockman
Joshtheclockman has a spectacular aura aboutJoshtheclockman has a spectacular aura aboutJoshtheclockman has a spectacular aura about
1994 SL
2002 SL
Default sputtery start and stall
I have a 2001 sc1 5spd with 117,000 miles. It has a problem, im a little stumped on. For a while now, and its been progessivly getting worse, it has not been hard to start but when you do its almost like it sputters to life, the rpms will jump to 1200 and then dive down to 600, then back up to 1000 and then back down to 700 and so on until it eventually levels out. It happens at stop lights but seems to run just fine. The sputtering only happens when you start it. Today it has apperently decided to start stalling at stop signs. The engine also likes to stumble when you let off the gas. I replaced what i thought was obvious, full tune up - spark plugs, wires, pcv, air filter, oil change. I also replaced the IAC and the EGR valve, hoping this might solve the issues. Does anyone have any ideas? Im at a loss here... Thanks
Add to Joshtheclockman's Reputation
Rate the quality of this post and help Joshtheclockman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Joshtheclockman is offline   Reply With Quote
Old 08-15-2012, 08:56 PM   #2
dsquare86
dsquare86 is on a distinguished road
2002 SL1
2001 SL2
Default Re: sputtery start and stall
Any codes?
Derek
2002 Saturn SL1 SOHC 5 Speed.
2001 Saturn SL2 DOHC 5 Speed - Retired.
Add to dsquare86's Reputation
Rate the quality of this post and help dsquare86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dsquare86 is offline   Reply With Quote
Old 08-16-2012, 05:01 AM   #3
1-Replaced the original round nosed plastic coolant sensor with a flat nosed brass one?
2-Searched for intake manifold gasket leak and testing by spraying water or throttle cleaner around the intake manifold (emphasis on cyl #1) while idling?
Old 08-17-2012, 09:29 PM   #4
Joshtheclockman
1994 SL
2002 SL
Unfortunately, it hasn't thrown any codes. I believe the coolant temp sensor is brass, i think that was the first thing i replaced, just because the round noses are no good. Ill check again because that could be the cause of all kinds of neat problems. Ill have to play with my can of cleaner on the intake, I havent even thought about it. It will have to wait until i get the car back. However, the problem does go away for a while when the battery is reconnected, which kinda leads me away from the intake, although I will still check it as it could still be the issue.
Thanks for your help guys
Old 08-18-2012, 08:16 AM   #5
Be sure the coolant sensor connector isn't fouled as this circuit works below 5v and resistance in fouled connections is interpreted as colder than normal coolant temperatures resulting in richer fuel mixtures. Poor connections can be result in erratic signals that would artificially raise and lower temperatures suddenly and affect fuel mixtures.
start then stall caused by alternartor. severedevil S-Series Tech 1 03-03-2012 11:37 AM
98 SC2 hard start and wants to stall on take off. MENGO1 S-Series Tech 4 03-26-2011 09:41 AM
SL2 stall and now wont start, HELP ME! paesanos S-Series Tech 11 12-07-2010 05:22 PM
94 sl2 start and stall loghome33 S-Series Tech 1 05-03-2007 07:39 AM
No start/stall/Hi rev/Temp gauge ok then off gchapell S-Series Tech 5 04-19-2007 03:01 PM
