Old 09-15-2011, 04:17 PM   #1
jacobs
jacobs is on a distinguished road
Default Engine RPM stay up when clutch is in
So this normally happens after a long trip on the interstate but can happen around town. What usually happens is when I put the clutch in to shift the RPM go to about 2,500 - 3,000 and hold there for 5-10 seconds. I tried replacing both O2 sensors but still the same problem. Any Ideas?
Add to jacobs's Reputation
Rate the quality of this post and help jacobs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jacobs is offline   Reply With Quote
Old 09-15-2011, 04:52 PM   #2
TomM96
Default Re: Engine RPM stay up when clutch is in
Hi Jake ,
Welcome
.The high idle is a common issue. Frequently it can be rectified by removal , and cleaning of , the ThrottleBody, as the butterfly occasionally becomes entrapped in pools of accumulated sludge (fuel/oil varnish). AutoZone sells CRC Throttle Body cleaner , Berklebile(sp?) also sells similar ... Gumout carb cleaner will work.
Try to avoid contaminating the ThrottlePositionSensor with the solvent, as it can deteriorate it.
Other causes ... as intake man leaks are indicated if issue chronic with clean TB.
>>> indicate parameters like model/mileage/vicinity/mods ... if want relevant responses.
Add to TomM96's Reputation
Old 09-15-2011, 07:36 PM   #3
Year and model?
Add to madpogue's Reputation
94 clutch replacement--must engine be removed to access clutch? agingric S-Series Tech 3 11-11-2010 10:30 AM
Clutch AND Engine RScottB S-Series Tech 11 05-28-2008 05:50 PM
Start engine w/o clutch RobertGary1 S-Series General 11 11-16-2005 02:50 PM
So got a new engine and clutch kit... kickarse Mods and Performance 0 10-12-2005 08:52 PM
Light (service engine soon) Stay on Flow S-Series Tech 2 05-01-2000 05:05 PM
