Old 04-22-2011, 12:02 AM   #1
WunderB0y
WunderB0y is on a distinguished road
2000 SL
Dizzy help please
hey, i have a 2000 sl and have had a lot of problems with getting the idle down was idleing at around 3500 changed the tp sensor and is now ideling around 2k cant figure out what else to do to get the idle down where its suposed to be, any ideas?
Add to WunderB0y's Reputation
Rate the quality of this post and help WunderB0y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WunderB0y is offline   Reply With Quote
Old 04-22-2011, 12:05 AM   #2
gizzi
gizzi is on a distinguished road
gizzi's Avatar
2000 SL2
2002 SL1
Default Re: help please
Possibly a vacuum leak. Could be the intake manifold gasket. Was the idle screw tampered with? Check engine light on?
Add to gizzi's Reputation
Rate the quality of this post and help gizzi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gizzi is offline   Reply With Quote
Old 04-22-2011, 12:29 AM   #3
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
First things first. Validate your ECTS is working as it should and only then start digging into other possible solutions.
1) Idle your car in the driveway and make sure the fan comes on automatically somewhere between 1/2 and 5/8. It should not take longer than 30 minutes for this to happen. When you hear the fan come on, validate temp drop is about 1/8 of the gauge.
2) If you pass test #1, go to your parts store and ask them to read your cars computer fault codes and report them back here.
3) if no codes have been set, I would buy a new ERG gasket ($2 just in case) and clean the ERG as demonstrated in this video: http://www.youtube.com/watch?v=bt5lRTt6BsU
Then try the car again. If the issue is not fixed then try this temporary test to see if the problem goes away. http://www.youtube.com/watch?v=8YRq2...e=channel_page
Report back what you find.
Add to ehunter's Reputation
Old 04-22-2011, 12:59 AM   #4
capricess
capricess has a spectacular aura aboutcapricess has a spectacular aura about
2001 SL
if its 2000 sl and you never changed it change it now because it has the plastic tip if cracks you will experience the high idle also when changing it check the connector for corrosion mine had the same problem and its 2001 sl. if its the egr you will get a code or when the car gets hot and you stop or shut the car and try to start it will start then die that the symptom of an egr
Add to capricess's Reputation
Rate the quality of this post and help capricess reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
capricess is offline   Reply With Quote
Old 04-22-2011, 07:34 AM   #5
Um, it's EGR, and unless there's also a performance problem, there's no point in risking INTRODUCING a vacuum leak by removing it. PRIME suspect for high idle on a gen-3 SOHC like yours is an intake manifold gasket failure, creating a vacuum leak. Test - start the engine, and while the idle is racing, spray brake cleaner or carb cleaner or the like along the mating edge between the intake manifold and cylinder head, esp. around the #1 runner. If idle changes, that indicates gasket has failed and that's the likely cause of the racing idle.
Add to madpogue's Reputation
Old 04-22-2011, 07:49 AM   #6
And because this is saturnfans, a search will yield a How To with pictures, videos, and sometimes both
http://www.saturnfans.com/forums/sho...d.php?t=115925
^ ^ ^ rc1488's How To is the current standard for the 3rd gen intake manifold gasket
Welcome to saturnfans, your one-stop shop for your saturn's needs
Old 04-22-2011, 09:32 AM   #7
capricess
2001 SL
after you spray around the intake if the rpm doesn`t change then replaces the ects its easy just be careful do not tighten it all the way in like i did or you will crack the brass tip
Old 04-23-2011, 02:01 AM   #8
WunderB0y
2000 SL
thanks for all the help, ill be sure to check these things, there was a few more things i would like to include to it as far as things it was doing just incase it ops out some of the ideas u have given me, the car upon start up will idle high for a few minnutes after that it will idle down to around 1200 after driving it for 10-15 minnutes the idle will then go up to and very from 2000-3500.
Im not sure if that will help as far as pinpointing it more but still, thanks a lot guys for all ur help. i will post again on here probaly monday or tuesday when i have had the chance to check all these things and let u know the verdict
