Old 04-15-2011, 12:17 AM   #21
radi
radi is on a distinguished road
Default Re: New (used) sc2 issues
Originally Posted by jbjones1 View Post
Will I damage the car in any way if I keep the EGR unplugged?
Nope. More than a few are running around with quarters underneath the EGR to block the passages.
Might be a problem if you live in a state that requires emissions testing.
Add to radi's Reputation
Rate the quality of this post and help radi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
radi is offline   Reply With Quote
Old 04-15-2011, 10:37 AM   #22
jbjones1
jbjones1 is on a distinguished road
I live in Nevada and we have emissions testing. I am going to buy a new EGR but I wanted to make sure that I wasnt doing damage by driving with it disconnected. Does anyone know if I can use an EGR from an S series sedan for my SC2? Im going to the junk yard to see if I can find one before I pay 137 dollars for the new one, and the yard has lots of SLs but not as many SCs..
Jared
Previously
1999 SL1
2005 Ion1
Add to jbjones1's Reputation
Rate the quality of this post and help jbjones1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jbjones1 is offline   Reply With Quote
Old 04-15-2011, 06:44 PM   #23
SaturnFix
SaturnFix will become famous soon enoughSaturnFix will become famous soon enough
SaturnFix's Avatar
It is mostly for emission control, but also for cooling the engine under some conditions. If the engine burns too hot, breaks pistons and valves. Not all that unlikely with a Saturn engine in the summer.
What is your Saturn's oil economy?
Canada Saturn owners REVOLT!!! Improper factory spark plugs! c.c
If you are in the Southern Wisconsin area, check out: facebook.com/SaturnFix
Add to SaturnFix's Reputation
Rate the quality of this post and help SaturnFix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFix is offline   Reply With Quote
Old 04-16-2011, 02:39 PM   #24
jbjones1
Default
could it be anything ezcept the egr? I went to my local salvage yard and picked up 2 egr valves in fairly good condition. I cleaned both of them and tested each of them. They all reponded with bucking an a jerking, but the car ran good when I unplugged them and they ran fine when I blocked the holeswith a gasket made from a aluminum can. Could it be the wires or something else. What its the chance that 3egr valves all did not work?
Old 04-17-2011, 12:25 AM   #25
radi
It sounds more like something is commanding the EGR to open when it should not. I assume the ECM controls the EGR, but don't know which other sensors might be involved for it to make the decision. That's beyond my level of knowledge with the Saturns.
Old 04-17-2011, 10:49 AM   #26
SaturnFix
SaturnFix's Avatar
So heres one for you. after cleaning the egr and replacing the plugs with copper, and the plug wires, i reset the SES signal and drove to work. At first it was great, but soon, just as before, after about 20 minutes and 20 miles the car started bucking again and acting like before and the SES light came back on.
The next step is to go back to Autozone and rescan those new codes
Old 04-17-2011, 02:00 PM   #27
jbjones1
Just got the codes read again. And they are all the same. Still the misfire code, the egr code, and the map sensor code. Can anyone tell me where the map sensor is located on a 2001 sc2. it is different than the ones in the richpin videos and diagrams I have seen. thanks again......
Jared
Previously
1999 SL1
2005 Ion1
Old 04-17-2011, 02:31 PM   #28
SaturnFix
SaturnFix's Avatar
Nevermind the MAP sensor code for now (it is probably tripped by a domino effect).
It is too bad you don't have a scan tool. Do you have a multimeter? Ignition on, engine off, unplug the EGR, facing the end of the connector with the clip on top, the 4th terminal should be around 5 volts.
Also, the voltage between the 3rd and 4th terminal should be around 5 volts.
On those 2000-2001 Saturns there was an issue: "instrument panel (I/P) wire harness coming into contact with a left side I/P bracket at the left side footwell area. Between the rosebud clip and the I/P connector, the harness may come into contact with the left side I/P bracket. Chafing the wiring harness may cause a short to ground"
Old 04-17-2011, 08:02 PM   #29
jbjones1
Default
I have a volt meter. Should I test the egr using paper clips on the holes the same way as if I were testing the map sensor?
Old 04-18-2011, 01:43 AM   #30
jbjones1
I have another question that I was hoping someone could help me identify. While doing some work and more troubleshooting, I noticed a sensor and plug that has been broken so it wasnt connected. Just behind my battery, there is metal blade about an inch thick and the same height and length as the battery. Just below this there is a sensor a little smaller than a dime with two prongs sticking straight up. The housing and plug had been broken off. I stuck it back on and temporarily wrapped it with electrical tape to keel it attched till i get a new one. Any ideas on what it is?
Jared
Previously
1999 SL1
2005 Ion1
Old 04-18-2011, 09:00 AM   #31
Interesting - could very well be electrical
The PCM uses TPS (throttle position), ECTS, MAP, IATP sensors to control the EGR
DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
3rd gen MAP location, courtesy of Low Saturn
Original link to photo
Old 04-18-2011, 09:53 AM   #32
jbjones1
Thanks. I think that it must be something electrical so now my troublshooting is a little more clear. Also the part that I mentioned in the post above I have since found out is the PCM. I guess in the 2000-2002 s series cars the PCM is right behind the battery.
Jared
Previously
1999 SL1
2005 Ion1
Old 04-18-2011, 10:33 AM   #33
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
I am wondering whether the ECTS is working properly.
Once the engine warms to a certain level is when the problems start. Suppose there was no response from the ECTS and the PCM thinks the engine was still cold even after 20 minutes of use. I could understand why it would run poorly.
Can you tell us how the temperature gauge behaves if the car just idles in the drive way for 20-30 minutes? Does the cooling fan in front of the radiator ever come on around 20-30minutes? If so at what gauge reading does the fan kick on?
Add to ehunter's Reputation
Old 04-18-2011, 11:30 PM   #34
jbjones1
just replaced the ects and tomorrow morning ill start it up and let is run for 20 minutes to see what happens and ill let you know what I found out.
Jared
Previously
1999 SL1
2005 Ion1
Old 04-18-2011, 11:31 PM   #35
jbjones1
Can anyone tell me what this is? It was broken off. I found a new one at the junk yard but I want to know what it is first?
http://www.youtube.com/user/jbjones1.../0/tTuDo29PNos
Also, while I have been looking for elecrical problems I wanted to see if anyone knew what these items are. This first is a video is with the panel on the second is with the panel down.
http://www.youtube.com/user/jbjones1.../0/ujatWVLmPyw
http://www.youtube.com/user/jbjones1.../0/xEVHTm4jWcA
As always thanks again.
Jared
Previously
1999 SL1
2005 Ion1
Old 04-18-2011, 11:57 PM   #36
The "blade" you refer to a few posts up is the PCM.
The part in the first video, if it's the last thing you pointed at in the video, that's the reverse light switch.
Anybody's guess what the aftermarket stuff is in the other two videos. It was rather badly done (wire nuts, crimp connectors, etc.). You'd have to follow where the wires go to know what the previous owner was up to (or call her/him, I suppose).
Add to madpogue's Reputation
Old 04-19-2011, 01:37 AM   #37
Meowth
Meowth is on a distinguished road
Meowth's Avatar
I have the same problem with my 2002 SC2, however my transmission is going out. My aunt had a SOHC but it blew up because of the poor engine design, so I have a DOHC in here now. The transmission always acted funny, but I was also thinking it could be the torque converter because it slips in 3rd gear and sometimes it takes a while to shift up or down. It also slams hard shifting lots of times, but I'm personally just waiting for the whole transmission to break. My car is still drivable, so when it becomes to the point of not working, I'll just go to a junkyard and swap it for around $1000 give or take. This may be completely unrelated to your problem, but this is just my experience with my Saturn. Both being SC2, it could be related, but I can't say for sure. I'm no mechanic.
Add to Meowth's Reputation
Rate the quality of this post and help Meowth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Meowth is offline   Reply With Quote
Old 04-19-2011, 10:20 AM   #38
jbjones1
So this morning I started the car. Upon start, the engine jumped to 1200 rpms for the first 3-5 minutes as the needle climbed to about 2 needle lengths left of the first mark. The needle stayed right there for the next 20 minutes without change, although the rpm did drop to 1100 after the first couple minutes. The engine fan was engaged and running the whole time. Granted I did switch out the ECTS last night so if it was a problem witht the ects maybe its fixed and my problems are over. (fingers crossed). We'll see how everthing runs after driving a little today. Usually when I drive (even before i switched out the ects) the engine temp needle stayed right around one needle width above the first mark.
I dont think its the transmission. I don't have any issue gears or shifting.
Jared
Previously
1999 SL1
2005 Ion1
Old 04-19-2011, 11:22 AM   #39
adventureoflink
adventureoflink's Avatar
When the fan ran "all the time", did you either:
1. have the A/C on (if equipped)
and/or 2. have the SES+hot lights on all the time
if the former, that's normal for the A/C; if the latter, that means your ECTS connector should also be inspected then replaced/cleaned as necessary. it's NOT normal for the fan to run all the time unless the A/C is on. If you had the SES+Hot light on before you swapped the ECTS (highly unlikely for whatever reason ) then you should pull the PCM-B fuse for a couple minutes to clear the code.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 04-19-2011, 12:42 PM   #40
ehunter
It sounds like your temp gauge is hovering at the right area, but I dont think your fan should be on the whole time. This means your computer is being told your temp coolant has reached 222 degrees or higher.
This can happen if your ectc wires are being shorted out which is he opposite of having corrosion on the head of ects connector.
A) Just for the sake of being thorough, look at the head of the ects connector and make sure there is no turquoise colored corrosion in the connectors holes where the pins go.
B) Then, look/trace down the length of these same wires to see if they have been cut/spliced in anyway. If so, validate the cut/splice is soldered. Solder them if they they not been.
If both A and B look good I would get a volt meter out and check the wires for a short somewhere as the lines make its way to the PCM. Let me know if you are not sure how to do this.
You did not have the AC on when you did the idle right?
2001 sc2
Weid issues please help. BC computer not accurate and other issues. turboguy327 Astra Tech 5 08-07-2010 10:06 PM
EGR issues curio L-Series Tech 4 06-19-2009 06:15 AM
'02 Vue issues BigGeezy Vue Tech 4 01-25-2008 08:17 AM
A few issues with my 03 Ion Soup Fan Ion Tech 6 10-13-2007 11:24 PM
VTI Issues? LelandC Ion General 3 01-28-2005 04:19 PM
