#1 | ||||
![]() Join Date: Jan 2011
![]() Hello everyone! I've been browsing around the forums for the last year or so, but I finally made an account to ask for some help.
My manual 1997 SL2 with 190k miles has started to dip RPMs below idle, down to as low as 400 any time pressure is released from the gas pedal, bounces back up to 1000-1100 RPM before dropping back down to normal idle at 800 RPM. Here's a video I took: youtu.be/HB9dl3rE0aI I've scoured these forums for answers, and have noticed a couple people having the same issue, but so far nothing has worked for me. (For example: 1997 SL2, 5 spd, DOHC. What I am describing happens at normal operating temperature. In slowing down when approaching an intersection, I will push in the clutch in anticipation of stopping. If I was at higher than cruising RPMs when the clutch is engaged, the RPMs will drop to around 600 and then rev back up to 1000+ before settling down. Then, when I am at idle (sitting at stop light), the idle seems to be right at 810-830. After 10 seconds or so, I will feel the engine ever so slightly shudder. Nothing major, but I've been watching the tach drop to around 780 or so, and then it pops right back to 810-830.) The list of things I've done so far is: Replaced PCV Valve Replaced engine coolant temp sensor (though with another resin tipped one, couldn't find a full brass one, but the original one seemed to be in perfect condition when I removed it) Replaced air filter Cleaned throttle body Cleaned EGR valve Changed oil Checked for loose/cracked hoses and subsequently tightened/taped them up Reset PCM after all of it All of which I've seen as potential solutions to the issue I'm having, but none of them seem to have worked. The engine sure runs a little smoother and quieter now, but this problem still persists. Any more ideas? I'm confident that someone here can help! ![]() I'll make sure to go rep all of the incredibly useful guides and posts that've helped me this past year while I'm waiting. Thanks everyone!
#2 | ||||
![]() ![]() ![]() Join Date: Apr 2009
![]() While you had your throttle body off, did you also clean the IAC valve? This'll cause your RPM to dip like this.
As for replacing an ECTS with the resin one, that shouldn't be.. I'd run and not walk from that place. All ECTSes (OEM/dealer or aftermarket) should be brass tipped by now. As to what condition the old one was in, by any chance, did you also check the connector for green corrosion? ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat
#3 | |||||
![]() Quote:
#4 | |||||
![]() Quote:
![]() ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat
#5 | |||||
![]() Quote:
Oh, and it's interesting that you mention the clutch, I replaced that 4-5k miles ago, the whole flywheel, disk, pressure plate and throwout bearing, along with replacing the ancient fluid in the tranny with some sweet amsoil fluid.
#6 | |||||
![]() Quote:
Good deal. I was kinda hesitant on suggesting replacing the IAC valve since you cleaned it but the symptoms were still there. however if you replaced it and the symptoms didn't get any better I didn't want you to be out $30 for playing parts bingo either... ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat
#7 | ||||||
![]() Quote:
#8 | ||||
![]() Mine has the same problem, even after a complete engine rebuild. Don't waste your money buying an IACV - mine's blocked-off completely in favor of a manual idle setup. Though it's that way for years, the idle surge problem still persists on mine. Have you solved yours? I've definitely had enough of this anomaly
#9 | |||||
![]() Quote:
#10 | ||||
![]() Hehe understood. I've been living with this for a while now myself, but after a bottom and top end rebuild, it's time to sort out allll these little faults. Best of luck to ye
#11 | ||||
#12 | ||||
![]() Turns out it was the spark plugs. For anyone else having this issue, give that a try!
#13 | ||||
![]() What ones did you put in? Congrats btw
#14 | ||||
![]() NGK Coppers. Some of the best plugs you can buy, and they're about $1.99 each. Real bank breakers, they are
#15 | ||||
![]() well right on, more mac in your pocket at that price
RPMs do not drop while coasting | Kotofeich | Ion Tech | 20 | 11-24-2009 11:41 AM |
RPMs drop then rise to normal idle after starting | s-seriesguy | S-Series Tech | 1 | 07-05-2008 06:44 PM |
RPMs drop when going to park | NVMY03GT | Ion Tech | 0 | 01-09-2008 08:24 AM |
drop rpms faster? | jump454 | S-Series Mods | 10 | 12-25-2007 12:14 PM |
Normal Operating RPMs | 2NDSOUT | S-Series Tech | 9 | 05-15-2004 07:16 AM |
