Old 12-31-2011, 12:17 PM   #1
saturn95
saturn95 has a spectacular aura aboutsaturn95 has a spectacular aura about
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Default Hard time starting after sitting for a few days
Hi guys, my 2001 SL2 sat for about a week and went I went to started, it started very badly and the rpm when idling was not stable. The exhaust also had lots of smoke and it smelled like gas. This is the second time happening. Once I run it for a minute or two, I can start it with no problems. The car runs great and has no codes.
Could this be an injector leaking and flooding the engine? If so, is there a way to test them before replacement them given that they cost 100 a piece?
Is there something else I should check?
Thanks in advance and happy new year!!!
Add to saturn95's Reputation
Rate the quality of this post and help saturn95 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn95 is offline   Reply With Quote
Old 12-31-2011, 01:20 PM   #2
satlite440
satlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud of
2001 SL2
Default Re: Hard time starting after sitting for a few days
it sounds like a leaking/clogged injecter..if you call your local gm dealer parts dept they should be able to give you the # for a bussness who cleans and flow tests injecters.. out here in seattle we use a place called"docter injecter"might be a franchise don;t know.. however be advised that older injecters that are cleaned like alot of the older ones like in the lt1v8 engines tend to fail with in a year or so...so you might just have them flow tested and if they are restricted just replace and not clean...
Add to satlite440's Reputation
Rate the quality of this post and help satlite440 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
satlite440 is offline   Reply With Quote
Old 01-04-2012, 09:50 PM   #3
saturn95
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Thanks for the reply!
Is this the only way to test the injectors? Does anyone know whether they can be tested by measuring their resistance or something like that?
Old 01-04-2012, 10:19 PM   #4
firstar
firstar is on a distinguished road
change the coolant temp sensor, usally the problem of rich start medium temp or cold
Add to firstar's Reputation
Rate the quality of this post and help firstar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
firstar is offline   Reply With Quote
Old 01-04-2012, 10:35 PM   #5
saturn95
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Good point, but I did change it about 8 months ago and I did it with the tip you guys recommended (I cannot remember which one it was). Can it still be that? Thanks.
Old 01-05-2012, 06:29 AM   #6
Pitcher
Pitcher's Avatar
It's probably not "that" again, but could be corroded connector to it, which is moderately common. If so, solder the wires together with a new connector.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Old 01-05-2012, 10:30 AM   #7
If anyone suspects any injector of leaking (not likely) then the easiest test, short of removing the fuel rail and injectors to lay out exposed while turning on the ignition, is with a fuel pressure gauge. Keep in mind several components when using a pressure gauge; the injectors, pressure regulator, pump check valve, etc.. Using a fuel pressure gauge can help eliminate doubts about the fuel system.
A fuel pressure gauge attached to the fuel rail's test valve will show immediate pressure as soon as the ignition switch is turned ON. The pump runs for 2-seconds than shuts off (for safety) unless the engine is started. Pressure should remain steady for at least 5-minutes and not bleed off. Holding pressure means; the pump check valve works, no lines are leaking, none of the injectors are leaking, and the pressure regulator isn't leaking. All by simply using a fuel pressure gauge.
Only '97's have a faulty pump check valve that bleeds off fuel pressure as soon as the 2-second time out occurs.
Old 01-06-2012, 12:22 PM   #8
saturn95
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Thanks guys, I will check the connector for corrosion and I will test the fuel delivery system with a gauge like you suggested.
Old 01-06-2012, 12:37 PM   #9
PlasticCarsRock
PlasticCarsRock is a jewel in the roughPlasticCarsRock is a jewel in the roughPlasticCarsRock is a jewel in the rough
PlasticCarsRock's Avatar
Do that. You can virtually rule out injectors and the rest of the fuel system by performing a pressure test. Many if not all autozones have a fuel pressure tester available as a loaner tool (it comes in a kit with a multimeter). Apparently they're not used very often, though, because the two times I went to borrow one (two different stores), they had no idea it existed and wanted to give me a compression tester instead (finally someone was able to find the right thing, after I insisted that they had it).
Add to PlasticCarsRock's Reputation
Rate the quality of this post and help PlasticCarsRock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PlasticCarsRock is offline   Reply With Quote
battery dead after sitting 5 days nailsgirl Aura General 4 06-18-2009 09:31 PM
tips for starting a car that has been sitting... saturn94v S-Series Tech 9 03-30-2009 01:49 PM
Engine miss after sitting a few days red92xblue S-Series Tech 4 02-10-2009 12:53 PM
Did the MMO today and had a hard time starting the car turbobuick33 S-Series General 15 12-26-2005 09:50 PM
Trouble Starting after sitting for a few days, fuel Regulator? badtzbuzz S-Series Tech 5 12-14-2005 11:52 AM
