Old 05-21-2003, 09:47 PM   #1
jcurrieirocz
jcurrieirocz is on a distinguished road
jcurrieirocz's Avatar
Default seat belt track motor (Help please)
my driverside seat belt track gets stuck on the corner and wont let me out of the seat so i have to unclip it..........but i knowticed today my batt goes dead if i dont drive the car every day or so....so i think my seatbelt may be the cause of it going dead how can i fix it or just turn that side off (disconnect the power)???
also where are the motors located and how hard are they to get at or fix ill unplug it untill i fix it atleast.
also what is the most common problem with them the track or the motors??
Thanks guys if you can help
Jeff
Add to jcurrieirocz's Reputation
Rate the quality of this post and help jcurrieirocz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcurrieirocz is offline
Old 05-21-2003, 09:52 PM   #2
wolfman
wolfman's Avatar
Default
Pull the fuse labeled PREST in the incar fusebox when the belt(s) are where you want them and there they will stay...IF however your battery is dying so quickly, it is also probably the source of the sticking problem. Lubing the track is a required maintenance item...see owner's manual for how to do it.
Add to wolfman's Reputation
wolfman is offline
Old 05-21-2003, 09:53 PM   #3
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
The biggest problem is that folks don't lubricate them!Mine stuck a few times,but always freed up,luckily.
Here's what the assy looks like.They are sold on FleaBay.
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 05-21-2003, 10:33 PM   #4
jcurrieirocz
Default
will silicon spray lube do it or is plain old grease anygood I have both here now.
Old 05-21-2003, 10:40 PM   #5
wolfman
wolfman's Avatar
Default
Use the GREASE applied with a small brush or cotton swab, the spray is too thin....the above posted picture is the assembly for the left (driver's side) door...
wolfman is offline
Old 05-22-2003, 12:58 AM   #6
jcurrieirocz
Default
this time ill do everything you say, wolfman to the rescue again!
remeber my rad that was leaking i fixed it with fiberglass it held for real good for a month or two then poped again... should of listend to you the first place Oh well its all better now my saturn likes the new rad.
Thanx guys also!
gann lube it asap if not pull the fuse fer now.
Seat Belt motor location...? saturn94v S-Series Tech 3 11-12-2008 02:00 PM
Seat Belt Motor Repair saturn94v S-Series Tech 4 05-02-2008 06:57 PM
pass. seat track on drivers seat? fetchitfido S-Series Mods 4 10-04-2006 10:40 AM
94 Seat belt motor 71_307 S-Series General 5 08-26-2003 11:20 PM
Automatic Seat Belt Track System R.J.Barnett S-Series Tech 8 08-24-2003 09:57 PM
