Old 11-11-2008, 04:19 PM   #1
saturn94v
saturn94v is on a distinguished road
saturn94v's Avatar
1994 SC1
Arrow Seat Belt motor location...?
My front shoulder belts do not work! At all! I optimumly would want them to slide back and forth when the door is ajar.(like they used to) I am an avid seatbelt user and not only that...its the law.() But any way...where is the motor? and how can I fix it? Or does this entail a replacement? either way It will have to be done very soon. Any info on the subject will be welcomed and appriciated! Thanks.
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
Add to saturn94v's Reputation
Rate the quality of this post and help saturn94v reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn94v is offline   Reply With Quote
Old 11-11-2008, 04:25 PM   #2
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
Default Re: Seat Belt motor location...?
The motor is under the trim in the piller right behind the front door. It's down close to the floor. You'll want to check your fuses first and check the module under the center console behind the e-brake. If drinks get spilled there, it cn fry that module.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 11-11-2008, 09:42 PM   #3
saturn94v
saturn94v's Avatar
1994 SC1
Question Re: Seat Belt motor location...?
It is a sc-1 coupe. it only has two doors. the motor is still under the trim in the piller right behind the door? and does each belt have its own motor? is a replacement module something I can find at the junk yard?
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
Old 11-12-2008, 02:00 PM   #4
Each belt has its own motor (imagine if they didn't!). If neither belt is working, it's more likely the PREST module (as described above) or fuse. Start there before tearing apart your interior.
Add to madpogue's Reputation
2003 VUE Rear Seat Belt Stuck ... Back Seat Won't Fold Up burnsej Vue General 5 08-28-2016 11:05 PM
'06 Vue rear seat belt won't let seat back up Steve-R Vue General 6 09-16-2014 06:14 PM
Seat Belt Motor Repair saturn94v S-Series Tech 4 05-02-2008 06:57 PM
94 Seat belt motor 71_307 S-Series General 5 08-26-2003 11:20 PM
seat belt track motor (Help please) jcurrieirocz Miscellaneous Tech 5 05-22-2003 12:58 AM
