Old 09-03-2007, 09:48 PM   #1
Steve-R
Steve-R is on a distinguished road
Default '06 Vue rear seat belt won't let seat back up
The center seat belt in our '06 Vue retracted fully when the seat back was laid down. Now the seat belt won't release, so the seatback is being held in the down position by the seat belt.
Has anyone had this problem before, and do you know how to fix it?
Thanks!
Add to Steve-R's Reputation
Rate the quality of this post and help Steve-R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve-R is offline   Reply With Quote
Old 09-04-2007, 11:23 PM   #2
the_webers_inc
the_webers_inc is on a distinguished road
the_webers_inc's Avatar
Default Re: '06 Vue rear seat belt won't let seat back up
Never had the problem, but I know how to fix it. When I bought my VUE (Used) I had to clean up after the previous owner. The back seat upholstery was a bit dirty, so I removed the seat to remove the upholstery to clean it.
The only way that I know of to release it is to unbolt the seat belt bracket at its base. Unfortunately, that means removing the seat. 5 bolt at the back, 2 in the front, and then the bolt holding the seat belt bracket. once you unbolt the seat belt bracket, you will be able to fold the seat back up and the seat belt should release.
If you need step by step instructions I can scan the rear seat removal procedure from the Saturn Service Manual I have.
Hope this helps,
T. J.
2000 Saturn SL2 1.9L 5spd - Sold
2003 Saturn VUE 2.2L 5spd - Sold
Add to the_webers_inc's Reputation
Rate the quality of this post and help the_webers_inc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_webers_inc is offline   Reply With Quote
Old 09-05-2007, 12:01 AM   #3
Still under warrenty?
2006 so unless you have an enormous amount of miles on the car it should be under warranty still.
Add to ssicarman's Reputation
Old 09-05-2007, 09:14 AM   #4
the_webers_inc
Originally Posted by ssicarman View Post
Still under warranty?
Good point. When I posted my instructions, I hadn't taking into account that Steve-R's VUE is most likely under warranty still. If so, Just take it to your Saturn dealer & they can do what I described for you free of charge.
T. J.
Old 09-07-2007, 12:53 PM   #5
GearGuy
GearGuy is on a distinguished road
GearGuy's Avatar
My Vue has a little plastic insert in the belt to prevent it from retracting too far. Or at least I thought that was the purpose of the thing.
IIRC, it is like a small plastic button midway in the seatbelt about the height of where it enters the seat back when fully retracted. Did this possibly get behind the seatbelt slot somehow?
2006 Vue 3.5L FWD
Add to GearGuy's Reputation
Rate the quality of this post and help GearGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GearGuy is offline   Reply With Quote
Old 09-13-2014, 12:04 PM   #6
Beeleonf
Beeleonf is on a distinguished road
These posts are so old, hopefully you all are still out there as I am wrestling with the problem. Dealer said they could fix, but $500 Car isn't worth enough for that. If you are still out there hoping you can share some of the R&R documents you have to help solve the problem.
Add to Beeleonf's Reputation
Rate the quality of this post and help Beeleonf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Beeleonf is offline   Reply With Quote
Old 09-16-2014, 06:14 PM   #7
billysvue
instructions:Unbolt the seat and seatbelt retractor
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
2003 VUE Rear Seat Belt Stuck ... Back Seat Won't Fold Up burnsej Vue General 5 08-28-2016 11:05 PM
Rear Seat Belt Inoperable darter1585 Vue Tech 3 03-03-2006 08:32 PM
Rear Seat Belt Retractors avlonfrg S-Series General 0 11-07-2005 03:32 PM
rear seat belt rattles Turducken Vue General 6 12-07-2004 08:46 PM
All Vue Owners Must Read My Daughter Got Traped Back Seat Belt vue4u2nv Vue General 10 09-30-2003 09:40 AM
