Old 06-17-2007, 09:11 PM   #1
misconceptionz
misconceptionz is on a distinguished road
Default 01 sc1 tranny probs
Allright so heres the problem. I have an 01 sc1 sohc but a few years back I did a swap to an sc2's transmission as the gear ratios were closer. At the time of this swap I had to take the car to saturn to get the computer flashed otherwise it wouldn't start. Well I haven't driven the car in a few years as it has been in storage. Before I put it away though I had to jump start the car and through the fluctuation of voltage while jumpstarting I have run into the same problem as before where the starter would not turn over when you tried to start it with the clutch in. My question is do you think that I need to get the computer re-programmed again or is there a way that I can trick the computer into thinking that the clutch is ingaged at all times so that it will alow the starter to work as I think it is a sensor that is different between the two trannys that is causing my problems.
Thanks
Add to misconceptionz's Reputation
Rate the quality of this post and help misconceptionz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
misconceptionz is offline   Reply With Quote
Old 06-17-2007, 10:55 PM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: 01 sc1 tranny probs
I thought with a manual, you didn't need to do anything to the computer. You can't use a DOHC auto on a SOHC motor, because of the computer, but for a manual, it shouldn't matter. Who did the swap? I think the issue is with the switch only. It can be by-passed, but I'm not sure how.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 06-17-2007, 11:46 PM   #3
Welcome to the Board.
Use standard no start diagnosis. If the engine is not cranking with the key make sure that your battery is ok. Check for corrosion at the terminals. Try boosting it. Make sure that you are getting a start signal to the starter via the small purple wire at the starter. If you have power to it when the key is turned to start then the starter is not working. If no power then you need to look up stream.
The starting system between the DOHC and the SOHC engines is the same.
Add to ssicarman's Reputation
Old 06-18-2007, 05:33 AM   #4
BarnOwl
BarnOwl's Avatar
There is no difference in sensors on a manual transmission. Nor is there any reason you would need to get the computer reprogrammed if you performed a swap from a manual SOHC transmission to a manual DOHC transmission. Going from an automatic to a 5-speed would require some reprogramming. However, if it ever ran properly, that's done and no more is necessary.
Do as ssicarman recommends and make sure the starter is seeing the 12 volts and work your way back from there.
Add to BarnOwl's Reputation
98 SC1 tranny problem jillz S-Series General 2 05-10-2009 08:23 AM
99 Sc1 5 spd tranny help 88z28ss S-Series Tech 3 02-08-2009 12:23 AM
SC1 Tranny issue...help please dodo S-Series Tech 1 10-02-2008 10:50 AM
97 SC1 Tranny problems chevy57 S-Series Tech 0 12-21-2007 08:48 PM
2000 L2 Wagon-tranny Probs HUNTINGSANTA L-Series General 0 06-20-2005 05:15 PM
