Old 05-02-2008, 04:32 PM   #1
saturn94v
saturn94v is on a distinguished road
saturn94v's Avatar
1994 SC1
Question Seat Belt Motor Repair
My 94 SC-1 coupe has an electric motor that is supposed to slide forward every time you open and shut the door. but lately it only hums(very annoyingly) as it is stuck in place. Any tips on how to fix it so it works? Or at least shut it off so it stops that eternal racket in my ear every single day!!
by the way it is stuck in the right position so at least it works to have my seat belt on. Would love to have it fixed though.
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
Add to saturn94v's Reputation
Rate the quality of this post and help saturn94v reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn94v is offline   Reply With Quote
Old 05-02-2008, 05:37 PM   #2
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
Default Re: Seat Belt Motor Repair
There are one of two solutions:
1. Find a replacement Seatbelt Motor, which is in the center console.
2. In your Instrument Panel Junction Block (On the Passenger Side of your car...Fuse Panel Access: Do the following:
A. Put your key in the ignition to get accessories running but not the car. (You will have the warning lamps on the dash lit up.)
B. Pull the Driver side Passive Restraint seatbelt connector toward you and to the back of the B Pillar.
C. Go to the Passenger side of the car and open up the Fuse Panel Access.
D. Pull the Fuse that is number 16 (P Rest). It is a Natural Colored 25 Amp Fuse. Once you pull this fuse, your Passive Restraints (Seatbelts) will remain in the same position regardless if the car is on or off.
If you do this, use common sense and still pull the belt across you when you drive, otherwise you may run the risk of getting ticketed for not wearing your seatbelt.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 05-02-2008, 05:54 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Actually the seatbelt motors are in the lower "B" pillar on the driver and passenger side. The control module is under the center console.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 05-02-2008, 06:10 PM   #4
2NDSOUT
2NDSOUT's Avatar
1994 SL2
1999 SL
Sorry, got those confused....usually it is the Control Module that needs to be replaced and not the motors, at least that is how I have understood it, but correct me if I am wrong...
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 05-02-2008, 06:57 PM   #5
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Could be one of em ,or both ,I have a good working driver side ,pas. side is D O A ,and unplugged at the motor itself .
I suppose if one works (like mine ) the module is still good !
if both are non functional ,you'd need to troubleshoot system .
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
2003 VUE Rear Seat Belt Stuck ... Back Seat Won't Fold Up burnsej Vue General 5 08-28-2016 11:05 PM
'06 Vue rear seat belt won't let seat back up Steve-R Vue General 6 09-16-2014 06:14 PM
Seat Belt motor location...? saturn94v S-Series Tech 3 11-12-2008 02:00 PM
94 Seat belt motor 71_307 S-Series General 5 08-26-2003 11:20 PM
seat belt track motor (Help please) jcurrieirocz Miscellaneous Tech 5 05-22-2003 12:58 AM
