Old 11-17-2006, 10:22 AM   #1
rlhdghhmh
rlhdghhmh is on a distinguished road
rlhdghhmh's Avatar
2002 SL1
Default Help ? on water pump and coolant
I am going to change out my water pump tonight, and I also looked in the how to library and found some step by step instructions. But I had a question on the antifreeze it says that I have to use dexcool antifreeze. But I have some regular stuff thats not dexcool here at work. If I use it will it do anything wrong to the car or should I use the recomended dexcool fluid.
2002 SL1 GO BIG OR GO HOME
Add to rlhdghhmh's Reputation
Rate the quality of this post and help rlhdghhmh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rlhdghhmh is offline   Reply With Quote
Old 11-17-2006, 10:27 AM   #2
jdcart
jdcart is on a distinguished road
Default Re: Help ? on water pump and coolant
It is my contention that the new "regular" antifreeze is up to the same standards as orange dexcool of years past. Therefore, I think it will be fine. Standard antifreeze is now compatible with all types and even now has reccommended 5 year change intervals (or 150K mile) so I would go ahead and use it. I just filled mine with the standard green, and I am not going to worry about it. Other input welcome.
Add to jdcart's Reputation
Rate the quality of this post and help jdcart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdcart is offline   Reply With Quote
Old 11-17-2006, 10:30 AM   #3
rlhdghhmh
rlhdghhmh's Avatar
2002 SL1
thanks on the info I didn't think that it would hurt ither just thought I would ask
Old 11-17-2006, 11:00 AM   #4
eljefino
eljefino's Avatar
1995 SW1
most likely if it says "5 year" anywhere on the regular antifreeze bottle it's OAT technology and dexcool compatible. The red color and dexcool name are licensed by GM... but the chemistry is more universal and will work fine.
Add to eljefino's Reputation
Old 11-17-2006, 11:10 AM   #5
HAzmat1
HAzmat1 is on a distinguished road
unless your car is under an extended waranty you should be fine it is noted that you should do a extisive flushing of the coolant system befor going to the green, I've seen problems because of corrosion due to incompatable mixes
Add to HAzmat1's Reputation
Rate the quality of this post and help HAzmat1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HAzmat1 is offline   Reply With Quote
Old 11-17-2006, 02:16 PM   #6
eljefino
eljefino's Avatar
1995 SW1
green silicated is practically obsolete and hard to find.
Green 5-year OAT is universally available and the kind one gets by accident when they're not specific what they want.
If anyone were to be concerned about mixing types, it should be someone with a 91 to early 96 with green silicated, accidentally getting green OAT. And even then the "mixing types" hype is debatable.
The OP, with dexcool forever, is in good shape, unless he/she scrounges for green silicated.
Old 11-18-2006, 03:24 PM   #7
rlhdghhmh
rlhdghhmh's Avatar
2002 SL1
I wnet and bought the napa auto regular brand and it says on the back meets GM 1899m will it work
Classic water pump coolant leak? cfg83 S-Series General 25 11-30-2011 07:42 PM
Leaking coolant, I think it's the water pump Seņor Ramos S-Series General 21 09-03-2009 06:01 PM
Coolant leak from water pump jonnycube S-Series General 36 08-17-2009 07:37 PM
Anyone have coolant leaks? Water pump? '03 3.0 V6 FWD johnbasler Vue Tech 6 11-28-2005 10:24 PM
MAJOR coolant leak--water pump? SweetErica S-Series Tech 10 12-27-2004 03:13 AM
