Old 10-29-2017, 06:42 PM   #1
'02SilverSL1
'02SilverSL1 is on a distinguished road
Default 2002 SL1 Rough Idle when in Gear and Stopped
I've been experiencing a rough idle, fluctuating between 500-600RPM, when I'm stopped at a traffic light or just stuck in the bank drive thru. When I put the car in park, the engine revs up to a constant 1100 RPM with no roughness at all. I get two codes. P0446-Evaporative Emission Vent System Performance and P0507 - Idle Speed High. The dealer performed a vacuum smoke test and found no leaks. I also replaced the gas cap and IAC valve, and cleaned the throttle body. Any suggestions on what I can try next?
Add to '02SilverSL1's Reputation
Rate the quality of this post and help '02SilverSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
'02SilverSL1 is offline   Reply With Quote
Old 10-30-2017, 12:05 PM   #2
toggenburg
toggenburg's Avatar
Default Re: 2002 SL1 Rough Idle when in Gear and Stopped
OK, so when you cleaned the throttle body and replaced the IAC, did you clean/replace the TPS since you had it all opened up, and did you get all gaskets back in correctly at reassembly?
Old 10-31-2017, 01:14 PM   #3
'02SilverSL1
I did replace the TPS also. And yes, all the gaskets were properly seated with no folds when I reassembled everything.
2002 SL1 Rough idle in 1st gear SILVER2002SL1 S-Series Tech 5 03-09-2011 04:49 PM
Rough idle/chirping noise when stopped in gear SLoneDC S-Series Tech 3 07-02-2007 05:21 PM
Rough idle when stopped and in Drive raiderfan S-Series Tech 4 07-21-2006 05:39 PM
Rough Idle Stopped in Drive thebidsnyper S-Series General 16 01-04-2006 06:06 PM
Rough idle when stopped on an incline. Phrosty3 S-Series Tech 1 02-27-2002 12:19 PM
