Old 10-27-2017, 11:36 AM   #1
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
Default Can I run an indicater light through the range-switch test leads
As the title suggests, I'm wanting to run a light through the test circuit.
So I will always know if its in the right "D" position or not by having an led on the dash.
So, can I put current through it, if so, how much, or is it already powered?
This switch,.. I don't like this switch, and it doesn't like me.
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 10-27-2017, 11:41 AM   #2
Default Re: Can I run an indicater light through the range-switch test leads
Is it that you are having an issue trying to make sure if you are in P, R, N, D + and your selector bulbs are burnt out or you are not quite dead-on the gear position?
That selector switch is adjustable to ensure you are exactly on where you want it to be.
Try this RichPin video:
https://www.youtube.com/watch?v=vjwxw8A08Sw
Thanks RICH!
Old 10-27-2017, 01:45 PM   #3
Nekomimi
Nekomimi's Avatar
1996 SL1
Mine slowly changes position over time, / is never 100% where its supposed to be even after adjustments, ive fought this every time done all sorts of things. Its also held on by one bolt, I popped the other one long ago, and its not any shape or form practical to get at and remove it. There's also a ridiculous amount if play between the shaft and the part that rotates witch causes ridiculous inconsistencies in position detection because its never going to land in the same place twice.
So I was thinking I'll put a light connected to the "D" continuity circuit so I'll know where it is all the time ^ .^
Old 10-27-2017, 05:02 PM   #4
Use an LED and low voltage source.
Cut a slot in broken bolt and get it out with screw driver. Be sure to smack the bolt repeatedly multiple sharp blows before atempting to screw it out.
A replacement range switch is not a bad idea either, P&P has plenty of them.
Range Switch Shenanigans Nekomimi S-Series Tech 12 10-04-2014 06:59 PM
P0706 code with new range switch fuadramsey S-Series Tech 6 09-01-2013 07:59 AM
DTC P0706 Trans Range Switch Performance ivymotorsports S-Series Tech 1 04-26-2009 12:12 AM
Automatic Range Switch, different!? KingRex S-Series Tech 4 03-17-2009 06:31 PM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 07:55 AM
