Old 04-07-2004, 01:03 PM   #1
dschrader
dschrader is on a distinguished road
dschrader's Avatar
2007 Outlook XR
2007 ION-2 Sedan
Default Rear Disc Conversion
Converting "The Bucket" to rear disc brakes. Was looking through Saturn's parts catalouge to make sure all my bases were covered and saw that there are two master cylinders for models with and without rear disc brakes. However SPS says the swap isn't needed ("all you need is in our kit")
My question is do I need a new master cylinder? The car is non-ABS.
Add to dschrader's Reputation
Rate the quality of this post and help dschrader reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dschrader is offline
Old 04-07-2004, 02:23 PM   #2
Tycho
Tycho is on a distinguished road
Tycho's Avatar
Default
all models with rear disc had ABS/trac...
all models without rear disc lacked ABS (pre 99).
The other master cyl will work fine as the proper brake bias is tuned into the rear calipers (based on their piston volume and such). Saturn won't have the non ABS master cyl listed as a "rear disc" one tho as it never was such in OEM fashon.
Forced induction is rape.
Add to Tycho's Reputation
Rate the quality of this post and help Tycho reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tycho is offline
Old 04-07-2004, 02:25 PM   #3
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
My newly-disc-ed 99 is running on the old, non-ABS master cylinder. Brake feel and performance are EXEMPLARY.
Listen to SPS, they know what they are talking about...
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
Add to bennett9000's Reputation
Rate the quality of this post and help bennett9000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bennett9000 is offline
Old 04-07-2004, 03:03 PM   #4
eRic 02sc2
eRic 02sc2's Avatar
Default
"My question is do I need a new master cylinder?"
the answer is No. the non-rear disc master cylinder works fine with rear disc conversions.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 04-07-2004, 03:13 PM   #5
dschrader
dschrader's Avatar
2007 Outlook XR
2007 ION-2 Sedan
Default
tycho,
Early coupes had discs without ABS, if I'm not mistaken
Old 04-07-2004, 10:38 PM   #6
JDub99SL2
JDub99SL2 is on a distinguished road
Default Re: Rear Disc Conversion
I hope you aren't going to seriously pay that much (SPS, $799 or whatever it is) for the conversion.... are you? I paid less than $200 for my whole setup, with new pads + rotors -- and I paid someone else to pull them for me (time constraints, otherwise I would've loved to have saved that $30-40).
Add to JDub99SL2's Reputation
Rate the quality of this post and help JDub99SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JDub99SL2 is offline
Old 04-07-2004, 11:30 PM   #7
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default Re: Re: Rear Disc Conversion
Yeah, but it was probably worth it in the long run.
I believe all rear disc equipped Saturns had ABS.
Add to SLeepr's Reputation
Rate the quality of this post and help SLeepr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLeepr is offline
Old 04-08-2004, 07:55 AM   #8
dschrader
dschrader's Avatar
2007 Outlook XR
2007 ION-2 Sedan
Default
Oh no I'm not paying $800, I have a 1992 SC parts car that will donate it's brakes, I was just checking on the master cylinder to make sure I had all the parts I needed to hook everything up.
And yes I have already planned for the wheelbase differences!!!
Old 04-08-2004, 03:03 PM   #9
JDub99SL2
Default Re: Re: Re: Rear Disc Conversion
:-D
Old 04-11-2004, 10:17 PM   #10
swzine
swzine is on a distinguished road
swzine's Avatar
Default
my post is off topic a little bit, but I saw no point in starting another thread with the same name on the same topic. Here's my question - would it be possible to do a rear disc conversion on my 03 L200? There are no kits on the market made specifically for my car. I think that rear discs may have been an option (or even standard for some years) so the parts may be out there.
"God Bless America, and no Place Else!"
-Head of State movie
Add to swzine's Reputation
Rate the quality of this post and help swzine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swzine is offline
Old 04-11-2004, 10:20 PM   #11
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
Default
Find an L200 with rear discs. Steal them.
Or if you do things legally, find a junked one, then steal em.
Add to TheSaturnKid's Reputation
Rate the quality of this post and help TheSaturnKid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSaturnKid is offline
Old 04-11-2004, 10:24 PM   #12
swzine
swzine's Avatar
Default
Ha! So it can be done is the answer??? I'll have to read some of the other posts to see how to do a conversion and how much work goes into it.
swzine is offline
Old 04-11-2004, 10:26 PM   #13
TheSaturnKid
Default
Yes anything can be done...
Old 04-12-2004, 09:42 AM   #14
dschrader
dschrader's Avatar
2007 Outlook XR
2007 ION-2 Sedan
Default
swzine,
Rear discs are standard and some model year L200s so parts should be pretty available. I'd assume it will be about the same process as my SL swap. All you need to do is swap equipment, run your lines, etc. It's just a matter of buying parts or finding a donor car.
Old 04-12-2004, 09:47 AM   #15
eRic 02sc2
eRic 02sc2's Avatar
Default
tycho,
you are mistaken. saturn never offered rear discs without abs. if they did i would have gotten my 92 sc like that and saved myself the fun of converting mine.
eRic 02sc2
Old 04-12-2004, 01:23 PM   #16
swzine
swzine's Avatar
Default
swzine,
Thanks for the input man. I'd love to get som discs on the back. What I really wish is that I could add ABS, but I think that's pushing the envelope a little too far!!!
swzine is offline
Old 04-12-2004, 01:37 PM   #17
dschrader
dschrader's Avatar
2007 Outlook XR
2007 ION-2 Sedan
Default
eRic,
Ah yes you are correct, I didn't think my donor car for brakes had abs but on further inspection it does. Oh well not the first time I've been wrong.....
Old 04-12-2004, 09:41 PM   #18
SLeepr
SLeepr's Avatar
Default
dschrader, I don't normally offer up such a prize.......but, I'll trade you my SL2 for your "other car?"
SLeepr is offline
Old 04-13-2004, 09:17 AM   #19
dschrader
dschrader's Avatar
2007 Outlook XR
2007 ION-2 Sedan
Default
Well it is better than the offer I recieved the other week,
Trade 1974 Firebird with 97,000, payments for another $15,000.
(by the way my car was appraised at $75-80K last spring).
But sorry think I'll still have to pass......
Old 04-13-2004, 08:36 PM   #20
LawMan
LawMan is on a distinguished road
Default
I've seen this topic pop up several times and I never get a round to asking if someone out there is willing to help me out. I dont want to pay for the overpriced SPS kit, but I dont have the time to search the local junk yards searching for the "Do-It-Your-Self kit". So my Questions are:
1. Is anyone in the Colorado Springs area that knows where I can get it?
2. Or if anyone is visiting their junk yard and is willing to hook me up with one?
My car is a 98 SC2. Any help here would be apricated, just pm me.
Add to LawMan's Reputation
Rate the quality of this post and help LawMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LawMan is offline
For those with rear-disc conversion Vertigoomg Mods and Performance 15 10-21-2005 05:52 PM
Rear disc conversion - no how-to? sps SOHC S-Series Tech 46 09-08-2005 09:24 AM
Rear disc conversion Masterson Ion General 7 09-06-2004 10:11 PM
Rear Disc Conversion JDub99SL2 Mods and Performance 11 02-07-2004 02:36 PM
Rear disc conversion Bar(long a) S-Series Tech 7 02-23-2002 08:04 PM
